+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Senior Member
    Using
    AutoCAD 2016
    Join Date
    Jan 2012
    Posts
    170
    Default Block transparency
    In block properties, you'll find the transparency option, but it does not seem to have an effect on the block at all, no matter what you set.
  2. #2
    Forum Deity steven-g's Avatar
    Computer Details
    steven-g's Computer Details
    Operating System:
    Win 7
    Discipline
    Construction
    steven-g's Discipline Details
    Occupation
    Draughtsman
    Discipline
    Construction
    Details
    I work in the estimating department of a large building contractor.
    Using
    AutoCAD 2018
    Join Date
    May 2013
    Location
    An Englishman in Belgium
    Posts
    2,159
    Default
    Indeed, that's is possibly by design (just a guess) looks like you might have to put the block on it's own layer and set the transparency for the layer.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  3. #3
    Super Member halam's Avatar
    Using
    AutoCAD 2017
    Join Date
    Jul 2015
    Posts
    697
    Default
    Search for the TRBB function on this forum
    It fixes trans 'byblock'..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  4. #4
    Senior Member
    Using
    AutoCAD 2016
    Join Date
    Jan 2012
    Posts
    170
    Default
    I found that if you change all the objects in the block to Transparency ByBlock, it will work, but I can not make it work for attribute text.
  5. #5
    Using
    AutoCAD 2017
    Join Date
    Jul 2015
    Posts
    697
    Default
    Hmm.. I Don't know
Similar Threads
  1. Transparency
    By buttonbutton in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jan 2016, 04:43 pm
  2. Block hatch fill transparency
    By david1-b in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th May 2013, 12:03 pm
  3. Transparency
    By StevenMc in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Aug 2009, 08:52 am
  4. 3D Transparency
    By alijahed in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Mar 2009, 06:00 pm
  5. Transparency
    By doobie in forum AutoCAD Drawing Management & Output
    Last Post: 11th Sep 2005, 03:41 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
