Complex Polyface Mesh to Solid
UserID
Hello everyone
I am using AutoCAD 14 in my company, and currently working on a project containing a complex blocks of buildings and walls.
some walls are complicated, and the customer provided only an AutoCAD drawing for the whole building in a polyface meshes. I need to convert the walls to 3d Solid entities so I can slice them and make through sections.
I saw there are a lot of threads speaking of the same here , but believe me, nothing worked with my case.
I put one of the walls right link to dwg here so you may see what I am facing.
p.s.: when I try to convert the big wall to a mesh or to solid using CONVTOSOLID command the computer got frozen and fatal error occurred!.
https://wetransfer.com/downloads/6f43c582453b03668c26e77ff31c266620170921141803/7fcef9c7b0a90ec7f82657c56b58eedd20170921141803/c20c67
Thank you in advance.
Regards
I tried a couple of different ways but they both ended with the explanation "cannot be converted" or it failed to convert because it was not watertight. Maybe someone else will have better luck.
A PFace mesh is a very odd duck. I believe converting it to a solid is an almost impossible task.
I can convert standard meshes into PFaces meshes. Not the other way around.
-David
I converted it to a bunch of solids by first exploding the mesh to 3D faces then using the Thicken command followed by Convert-to-Solid. Unfortunately I could not union it into a single entity.
I see. Thank you both.
Using Revit, a friend of mine succeeded to convert it to a bunch of surfaces.
I think that's a limit for this poor structure.
Wisam
Amazingly I think yours can actually be done. :o
A very complex operation
Explode the PFACE MESH
Convert each 3DFACE into a general 3D mesh (39,000 +- ) see code below
Convert each mesh to a solid
Union all soilds
This is only possible because all points are coincidental and form a closed model
[b][color=BLACK]([/color][/b]defun c:3df2mesh [b][color=FUCHSIA]([/color][/b]/ ss i en ed p1 p2 p3 p4[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"3DFACE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]princ [color=#2f4f4f]"\t\t\r"[/color][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]prin1 en[b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b]
                   p1 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                   p2 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                   p3 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 12 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                   p4 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 13 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"POLYLINE"[/color][b][color=BLUE])[/color][/b]
                            [b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b]
                            [b][color=BLUE]([/color][/b]cons 66 1[b][color=BLUE])[/color][/b]
                            [b][color=BLUE]([/color][/b]list 10 0 0 0[b][color=BLUE])[/color][/b]
                            [b][color=BLUE]([/color][/b]cons 70 16[b][color=BLUE])[/color][/b]
                            [b][color=BLUE]([/color][/b]cons 71 2[b][color=BLUE])[/color][/b]
                            [b][color=BLUE]([/color][/b]cons 72 2[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"VERTEX"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 10 p1[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 70 64[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"VERTEX"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 10 p2[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 70 64[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"VERTEX"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 10 p4[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 70 64[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"VERTEX"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 10 p3[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 70 64[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"SEQEND"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
Nice one David!
Theres a small addition that can be done - add an option to erase the source 3DFaces:
Add this inside the loop:
(setq sL (cons en sL))
Add this after the loop:
(and sL (= "Yes" (progn (initget "Yes No") (cond ( (getkword "\nErase source ? [Yes/No] <Yes>") ) ("Yes")))) (mapcar 'entdel sL))
Ofcourse don't forget to localise the "sL" variable.
Thats a handy feature for such kind of routines (I noted this from Lee's outline program).
  • 1 year later...
Union all soilds
-David
Thank you again
@ David, why I have the code looking like mumbo-jumbo lines, am I missing something here?
