+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Full Member
    Discipline
    Manufacture
    neondeon298's Discipline Details
    Occupation
    CAD Specialist / NDT
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    38
    Default Restrict saving of "master" dwgs
    So my company uses master drawings for kits or other metal specimens. However, too many times the A master or B master gets stuff saved over it (its no longer A master but #5002).
    Besides the obvious of NOT hitting save... is there a way to make that drawing "Read-only" and I have to do a SaveAs?
    Is clicking "read only" check box in Windows Explorer an option?
    Thanks
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,865
    Default
    Your master drawings should be .dwt files not .dwg files.
  3. #3
    Senior Member dtkell's Avatar
    Computer Details
    dtkell's Computer Details
    Operating System:
    Win7
    CPU:
    Intel I5 4670
    RAM:
    16mb
    Discipline
    Civil
    dtkell's Discipline Details
    Occupation
    Drafter/Designer
    Discipline
    Civil
    Using
    AutoCAD 2014
    Join Date
    Dec 2006
    Location
    San Diego, CA, USA
    Posts
    153
    Default
    Quote Originally Posted by ReMark View Post
    Agreed.
    The Windows Explorer "Read Only" option will work if you are the only person with the authority to change that.
  4. #4
    Full Member
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    38
    Default
    ReMark... are .dwt efficient when there are hundreds of masters saved in locations based on the product type? Example: A magnetic kit is saved in folder for mag kits, and xray kits are saved in that folder. Would that mean I have those .dwt in each of those folders or better to have all .dwt in one location? I also noticed that I can save-over .dwt. I sadly work with people who fumble around and click save when they shouldnt far too often.
  5. #5
    Full Member
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    AutoCAD 2017
    Join Date
    Dec 2016
    Posts
    38
    Default
    The "read only" method is nice just because it is a deterrent to save-over. Guess its time for the long arduous process of making them all read only.
  6. #6
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,581
    Default
    it wont be a long process just have to be old like me and use DOS which is still available and use a bat file, will try to remember. There may be a vl set file read only so could do a lisp.
    Go to the world lower left
    CMD
    then use dos change drive etc if network eg
    G:\
    cd \dwgs\magkits
    attrib +r *.dwg /s
    may need to be administrator the /s means include subdirectory.
    do the cd\dwgs\xray and so on repeat as required should only take a few minutes.
    using Dos_lib inside Autocad
    (dos_attrib "c:\\alan\\*.lsp" 9) ; 8 archive + 1 for read only
    https://wiki.mcneel.com/doslib/home a great library of functions you may need to download.
    if you can give a better picture of your drive structure we can help.
Similar Threads
  1. Replies: 18
    Last Post: 10th Apr 2014, 05:23 pm
  2. Renaming attributes tags according to a "master" drawing.
    By liormic in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jun 2012, 06:20 pm
  3. Restrict startup = 1 to "Choose a template"
    By ynotrobits in forum AutoCAD Beginners' Area
    Last Post: 8th Apr 2012, 02:58 am
  4. saving as "step" and/or "inventor" file
    By jmatus86 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th May 2011, 01:56 pm
  5. pdf files much larger than "parent" .dwgs
    By OldMikeNewMember in forum AutoCAD Drawing Management & Output
    Last Post: 9th Sep 2010, 08:31 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
