Results 1 to 2 of 2
    Full Member
    AutoCAD 2017
    Dec 2015
    Aus
    88
    Default object selection
    Hi All,
    I have this strange problem with autocad where it doesn't seem to select or deselect things properly.
    ie I will have a bunch of items selected but properties say I have nothing selected. Then if I press escape to unselect, they stay highlighted (but still says no objects selected). and only way I've found to fix this is to restart autocad which is a pain. it seems to happen randomly too. it will be working fine for hours then I notice this happening and need to restart to fix. anybody else have this happen or heard of this happening before?
    I've attached pic showing how it says "No selection" even though you can clearly see I have some lines selected
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    Do you have all of the updates?
    This has been a problem in the past for AutoCAD.
    You may have to run a repair, if that doesn't fix it, you may need a clean uninstall/reinstall.
    It appears Autodesk site is having some difficulties, all pages related to this error are showing "The website that you're trying to reach is having technical difficulties and is currently unavailable."
  1. Object selection
    By hessoka in forum .NET, ObjectARX & VBA
    Last Post: 6th Jun 2014, 04:29 am
  2. Trim selection & Object selection problem
    By Kurt Crim in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2011, 12:19 pm
  3. Object selection
    By Tekenmeester in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Jan 2010, 07:45 am
  4. object selection
    By salman in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Aug 2009, 05:04 pm
  5. help with object selection
    By S.T.A.R.S.MEMBER in forum AutoCAD Drawing Management & Output
    Last Post: 29th Mar 2006, 12:02 am
