Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Default Solid to triangular faces?
    How can I convert the surface of my solids to triangular faces? In the past I did it by exporting to 3DS (if I remember right) and reimporting it, but AutoCAD 2015 doesn’t support any more that format.
    I tried to export in STL format (it worked), I opened the .STL file in Inventor (it worked too) and I exported from Inventor in DWG format again. But opening that last DWG in AutoCAD gives nothing .
    I am not up to date with this modern AutoCAD, the last one I used daily was AutoCAD 2006. Ca someone help me please?
    Yhank you for the welcome!
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I know of a routine that will convert a solid to either 3Dmeshes or 3Dfaces. Would that be of any use?
    Here is an image of a solid that I converted using the routine.
    BTW...welcome back fuccaro.
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    Couple of days ago I discovered XEDGES which will create a wireframe of a solid on top. This could be used in combination with edgesurf for creating meshes, not regions which will be result of exploding solids.
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Nobody suggested exploding a solid. We're talking a straight conversion from solid to triangular faces or at least that is my interpretation which is what I believe I show in the image previously posted.
  5. #5
    AutoCAD 2017
    Jul 2015
    699
    O Sorry than
  6. #6
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    Thanks for the answers!
    XEDGES just extracts the edges from a solid, I need something like "XSURFACES". To get the individual edges doesn't help me since I try to use the surface in a Lisp program.
    ReMark, that program sounds good, may I have it please?
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    This is the program description:
    Sol2Mesh
    and Sol2Faces - convert 3DSolids to 3DMeshes or 3DFaces (VLX Lisp for AutoCAD 2011/2012).
    This is where it can be found:
    http://www.cadforum.cz/cadforum_en/dl_file.asp?ID=1444
    This is a copy of the program which, in order to upload it, I had to add the .zip file extension although it is NOT a zip file. Download and rename the file by removing the .zip file extension and you are good to go.
    sol2mesh.vlx.zip
  8. #8
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    Thanks, I downloaded it and I will give it a try tomorrow.
  9. #9
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Whats the point/advantage of triangular faces?
  10. #10
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    The program works just fine, thank you again, ReMark!
    bjenk8100, writing Lisp programs sometimes I need to find out coordinates on the existing solids. If you try ENTGET on a solid, AutoCAD will return a list that only Einstein's brain can understand. Working with triangles or even with mesh objects is much simpler.
  1. Creating a solid from 3D Faces
    By tazzzz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Feb 2017, 02:09 pm
  2. change the angle between the two faces of 3D solid
    By 77077 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Mar 2015, 03:09 pm
  3. How to convert several triangular regions into 3D solid?
    By yeti in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Dec 2009, 01:40 pm
  4. Rendering faces of a solid in 3D Max
    By xoom2 in forum UVW Mapping, Textures & Materials
    Last Post: 1st May 2004, 11:50 am
  5. Extrude faces on a solid
    By Orbit in forum AutoCAD General
    Last Post: 23rd Jun 2003, 04:56 pm
