Results 1 to 3 of 3
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Default Moving from 2014 to 2018...Ouch!
    I've been using AC 2014 for the last several years. Getting ready to make the jump to 2018 to use the new rendering feature. The first problem I'm running into is that when I turn perspective to 1 and then use the mouse to zoom in, the object I was just looking at disappears. I can go back to the previous view and the object is there but even a single toggle of the mouse wheel apparently zooms in so close I can no longer see the object. When perspective is set to 0 this doesn't happen. Similarly, when I zoom the object to a comfortable view with perspective set to 0, and then set perspective to 1, it again disappears, or again, apparently it zooms in so close I can't see the lines of the object.
    So what is it I'm doing wrong? I can open the same drawing in AC 2014 and this problem is not happening.
    It's deja vu, all over again.
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    I found that turning down the ZOOMFACTOR variable from 60 to 10 made a big difference. Still I can see that this update to 2018 is going to hit my cash flow by needing a new graphics adapter to handle things. I just wish the people who make software could be more understanding that the small business people are not made of money like Fortune 500 companies are.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,097
    That should always be considered in the cost of updating software, sometimes a necessary evil.
    If your plans are for rendering, you should definitely consider a computer/graphics card upgrade.
  1. AutoCAD 2018.1 and AutoCAD LT 2018.1 Update Now Available
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 28th Jul 2017, 01:10 am
  2. Can I tell 2014 not to show whole xref when moving xclipped reference?
    By Glen1980 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2014, 08:07 am
  3. Moving from AutoCAD 2002 to AutoCAD 2014...block issues
    By spaulus in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2014, 12:56 pm
  4. AutoCAD 2014 & Revit 2014 Free Book Titles Released
    Last Post: 31st May 2013, 08:20 pm
