Results 1 to 1 of 1
    Junior Member
    mhmtlgrr's Computer Details
    Windows 7
    HP Workstation Z240
    Architectural
    mhmtlgrr's Discipline Details
    Architect
    Architectural
    AutoCAD 2015
    Jul 2012
    12
    Exclamation How to get data to an attribute from enclosing polyline's property
    Dear folks,
    There is an idea to get things easier in my workflow but I need check if it is possible or not.
    There are over 100 closed polyline objects on the model and each has a unique ID written in its Hyperlink value (like X_D_YYYY)
    And each of these polylines has a block placed in the enclosing area with an attribute.
    My aim is to get the Hyperlink from enclosing polyline and populate the block attribute with that value.
    You may find an example as DWG at the attachment.
    Regards.
  1. BLOCK ATTRIBUTE to POLYLINE OBJECT DATA
    By Lee94 in forum Map 3D
    Last Post: 23rd Jul 2017, 01:34 am
  2. Select Blocks by Name & Attribute Property
    By churchill in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Nov 2013, 01:34 am
  3. Can't edit attribute when inserting excel data that has 3 lines of data
    By Findermb in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 12th Jun 2013, 02:34 pm
  4. adding data to polyline and extracting this data to table?
    By feargt in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2013, 08:04 pm
  5. Object Data to Attribute Data to perfection
    By cris2fur in forum AutoCAD General
    Last Post: 30th Nov 2011, 06:39 am
Tags for this Thread
