Results 1 to 5 of 5
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Default Press/pull command
    Hello,
    If you use press/pull command from 2D circles are you suppose to delete 2D circles after the command. Just sick of them popping up on quick properties menu. I know they arent there with solid extrude. Sometimes I have to do press pull for more complicated shapes.
    Cant seem to geoconstrain in 3D. Looked it up on autodesk and it says geoconstrains are only in 2D. What??????
    AutoCAD 2013
    Nov 2011
    6,051
    The system variable which controls this behavior is DELOBJ (for delete objects), as shown you can change this in your OPTIONS on the 3D Modeling tab.
    Look in your SYSVDLG, and you will find a wealth of information.
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Thanks,
    Thought that was weird. Besides that, no geoconstraints in 3D. Real pain relying on wireframe to move stuff around by midpoints and what not. Cant believe you cannot constrain a center of one solid to another without snaps in a 3D environment.
    AutoCAD 2013
    Nov 2011
    6,051
    Are you familiar with the 3D Object Snaps? If not, you should be.
    No constraints involved, but they do have their uses.
    The Center of Face one is pretty cool.
  5. #5
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Constraints are essential. I like to be able to rotate and slide objects about other objects and what not. I think autocad is great for 2D. I wish Inventor was the 3D workspace. Back where I started. Autocad for 2D and Inventor, Solidworks and Revit for 3D.
  1. Press/pull problem
    By tonyj in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Dec 2012, 01:02 am
  2. press pull command moves ucs in xy plane (ACAD 2011)
    By sevdo2000 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Feb 2011, 10:43 am
  3. Can't press/pull
    By lanetheme in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Dec 2010, 10:57 pm
  4. Press/Pull
    By Kobbe in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Jan 2010, 08:53 pm
  5. Press pull issues
    By Buzzy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Feb 2009, 11:53 pm
