+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Junior Member
    Using
    AutoCAD 2016
    Join Date
    Jul 2016
    Posts
    12
    Default Relieved point received
    How can I select this point and its description so that civilian (2017) incorporates it into a group of points or export it to a list (txt / csv). (I must also include the description).
    Is there a way to do it with some menu command?
    Thank you.
  2. #2
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,702
    Default
    Not a problem use the point group properties, just add a point group with your conditions.
  3. #3
    Junior Member
    Using
    AutoCAD 2016
    Join Date
    Jul 2016
    Posts
    12
    Default
    The civil is not recognized as an entity to include in a group of points.
    Is there a way to convert or export it to a listing?
    Regards.
Similar Threads
  1. Four Legged Friends will be Relieved at the PDX Airport
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 4th Oct 2016, 11:20 pm
  2. Just received Windows 8 Pro from UPS
    By Currahee in forum Software & Licensing
    Last Post: 20th Dec 2012, 11:27 am
  3. Received a dwg but scale is not compatible
    By Amy in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Apr 2008, 09:57 am
  4. just received a PLT file...
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Sep 2007, 12:15 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
