Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    Landscape
    Revit 2017
    Sep 2017
    8
    Default 3D Faces ri a single enclosing 3D Polyline
    Hello,
    I have a series of 3DFaces provided by the project civil engineer - these elements represent footpaths, roads, cycleways etc. These elements are sloping on various grades as one would expect. I'd like to generate a 3D Polyline that forms a boundary around all the elements that form a section of road or footpath. I can use the 3DPoly tool to visit each external vertex and snap to the vertex but is there a tool or Lisp program that can do this automatically? I've tried the LineworkShrinkWrap command but that doesn't retain all the correct Z values for the external vertices.
    In the attachment, the layer DESIRED RESULT (magenta) is what I am trying to achieve.
    Many thanks in advance!
    3DPolyTraceQuery.dwg
    Forum Newbie
    Landscape
    Revit 2017
    Sep 2017
    8
    Default Updated CAD example
    I've updated the CAD example to fully illustrate the problem
    original 3d faces (CYCLEWAY layer - brown)
    lineworkshrinkwrap (LINEWORKSHRINKWRAP layer - yellow)
    desired result (DESIRED RESULT layer - magenta)
    The desired result was manually created by tracing the extent of the 3DFaces using 3DPOLY command.
    Hopefully this makes more sense?
    Attachment 62305
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    I am confused the magenta and yellow are the same.
    Using shrinkwrap in CIV3D outputs a 3dpoly what you want.
    Your profile says Revit is this correct ?
    Forum Newbie
    Landscape
    Revit 2017
    Sep 2017
    8
    Bigal, thanks for your reply. I have to disagree. LINEWORKSHRINKWRAP in Civil3D doesn't do what I want. The magenta and yellow lines are different. The magenta line is what I want. I've attached some screenshots - you can see the difference between the original 3D faces, the 3D polyline (magenta) manually traced using 3DPoly and the result from running LINEWORKSHRINKWRAP in yellow.
    BTW - my profile is correct - I am using Revit mostly, and this particular workflow is to allow me to create Revit Floors automatically from Civil3D elements using Dynamo.
    Original 3Dfaces = brown
    Manual trace with 3DPOlY = magenta
    Shrinkwrap = yellow
    Difference shown in the last image
    Original 3D Faces.JPGManual trace using 3DPOLY.jpgLINEWORKSHRINKWRAP result.jpgDifference between manual trace and shrinkwrap.jpg
  5. #5
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    Revit has nothing to offer? So you're looking for a workaround for a workaround based on conversion using (the famous) Dynamo..?
    I think you just should not use Revit and DWG for Civil use in the first place. You're asking for trouble, world of pain, still leads to DWG in the end.
    My cent!
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  6. #6
    Forum Newbie
    Landscape
    Revit 2017
    Sep 2017
    8
    Thanks for your reply Halam. I'll take it on board.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    You might check and see if there is something in CADTools that can do what you want.
  8. #8
    Forum Newbie
    Landscape
    Revit 2017
    Sep 2017
    8
    Thanks SLW210. I've got CadTools and I can't see anything that would achieve what I'm after.
  9. #9
    AutoCAD 2017
    Jul 2015
    699
    Quote Originally Posted by Steve Wheatley View Post
    Thanks for taking that as my bold reply ;-)
    I'm not sure you want to stick to Autodesk 'infra sollutions potfolio' either as a matter of fact
    Why not try to find a more exotic and suitable elsewhere, i noticed some great things hapenning at Sketchup. Which most of the times is fairly good dwg compatible. Way better than the Revit beast. I'm not familiar with .skp abilities within the Dynamo playfield. Centainly there can be found some workflow skp into Revit.
    Check this
    https://youtu.be/-WzsUQTonmk
    https://extensions.sketchup.com/en/content/edge-tools²
  10. #10
    Forum Newbie
    Landscape
    Revit 2017
    Sep 2017
    8
    SLW210 - I stand corrected. CadTools DOES have what I needed! Convert 3DFaces to 3DPolylines. It seems to do exactlty what I want. Glad I went back and had a closer look. Many thanks for your time and suggestion.
    In case any other newbie needs to know CadTools can be downloaded from here: http://www.glamsen.se/CadTools.htm
  1. How to get data to an attribute from enclosing polyline's property
    By mhmtlgrr in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Sep 2017, 04:31 pm
  2. Replies: 2
    Last Post: 10th Feb 2016, 02:27 pm
  3. Converting 3D Faces to a single Surface (or Polyface Mesh)
    By Ron-O in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Aug 2012, 12:39 pm
  4. Single polyline on more than one layer
    By eldon in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 24th Jan 2011, 09:43 am
  5. Single lines into polyline?
    By Christian Syversen in forum AutoCAD General
    Last Post: 21st Nov 2003, 09:40 pm
Tags for this Thread
