Results 1 to 7 of 7
Thread: extrude problem
    Forum Newbie
    Electrical
    AutoCAD 2013
    Sep 2017
    3
    Default extrude problem
    I am a newbie, Am using Acad 2013. I did not know how to title question enough to search if it has been answered before. I have been doing exercises on Mr.Z youtube channel, everything was just fine. The cube project started and if I drew a square and tried to extrude it by same unit as x-y it always now ends up as a very short 3d box instead of all 3 axes equal. I have created gears and completed a 3d house with no trouble. what setting did I mess up?
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    How are you entering the height ?
    Forum Newbie
    Electrical
    AutoCAD 2013
    Sep 2017
    3
    i draw equal square with rectangle command typing any same unit. If units set to mm i enter 10 units for example for one dimension then tab and 10 for the next, enter, I get a perfect square, then I use tilt drawing a little and use extrude command, pick my square and drag it upward.... it follows upward ad usual waiting for you to pick a height, so I type 10 units in and hit enter.
    I get a very short cube. it is as if Z axis units are less than X and Y.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Works for me do you have Snap on this may cause a problem. You don't need to be in a 3d view as you do extrude just feel confident and enter height when prompted then check -vpoint 1,1,1 You can use -10 to go down rather than up.
  5. #5
    Forum Newbie
    Electrical
    AutoCAD 2013
    Sep 2017
    3
    Still a problem, this is simple operation i have done dozens of times. I should be able to start a new drawing and draw a square and extrude it to a cube. the unit does not seem to be the same on z as it is in x and y. I can enter 1 or 10 or 100 units on each parameter and I currently get a square box that is very short.
  6. #6
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,312
    Not sure why this is happening? Have you tried closing and restarting Autocad?
    I have moved your question to the 3D Modeling section: http://www.cadtutor.net/forum/forumd...-amp-Rendering
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Re check snap option Aspect has two options Hor and vert they can be different.
  1. problem in extrude
    By mirvakili in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jul 2014, 09:46 am
  2. Problem with extrude
    By shwell in forum 3D Modelling
    Last Post: 24th Sep 2012, 10:10 am
  3. problem with extrude
    By mahmoud abdallah in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Dec 2009, 06:15 pm
  4. Extrude Problem
    By Memnon in forum Autodesk Inventor
    Last Post: 24th Mar 2009, 11:53 pm
  5. 3D Extrude Path problem
    By tzframpton in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th May 2006, 05:41 pm
