Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Default back to picture to cad
    This might work. Get two string lines from porch or whatever part of house/structure and plum line it out level to area straight away from structure. We have string lines with levels. Then level a stand perpendicular to string lines with camera. That way it is straight shot unless I am missing something. Then picture should be traceable. Then measure 1 object physically and scale it in cad. If I am missing something please feed.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    Why? there are programs that do this. If you are going to go to all the trouble of usings strings and levels. for every picture you may just as well measure the stuff.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    we run outta manpower. surveyors r doing government jobs. if this works i will be fond. I cant take the heat to bring union onto residential with all that crap. I want to do it myself.
    I love the unions they do good for me but they are not good at particular crafts. I teach them carpentry and they laugh. "Thats too artsy"
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by bjenk8100 View Post
    That will work. If you get a camera perfectly perpendicular to the plane of the measurable object, other objects on that plane can be measured. Those other objects, though, have to be coplanar. Not just parallel, but perfectly coplanar.
    Experiment with AutoCAD, a camera, 3d Solids, and the Flatshot command to confirm or refute any of these notions.
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    Perfectly coplanar! Imagine a window opening 1 meter wide, with a window frame set back in the opening by just 10cm it is still in reality 1 meter wide. Now take a photo with the camera at a distance of 2 meters perfectly in front of the brickwork. And scale your photo so that it shows the brickwork opening at 1 meter then your window frame will measure just 952.381 mm. If your happy with that level of inaccuracy then OK but be aware measuring from a flat photo will only work if you are taking photo's of perfectly flat objects, and then you need to take into account photographic perspective.
  6. #6
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by steven-g View Post
    That all sound about right.
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Level a stand? How about starting with a good tripod?
  8. #8
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    All pictures are a perspective view. Although you can get a good approximation if you are far enough away, you cannot get truly accurate dimensions.
    Drafting is a breeze.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    A guide to architectural photography states, "By photographing your architecture from a long way away and using a long focal length lens (telephoto), you will flatten the perspective, making the lines of the building appear parallel..."
    You might also want to read up on tilt shift lens useful in "eliminating the convergence of parallel lines". This is especially true when photographing tall buildings.
  10. #10
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,658
    You are talking about Photogrammetry, making measurements from photographs. You could always take lots of pictures and as many measurements as possible and then use SketchUp's Match Photo tool to create a 3D model of the structure/facade and then bring that back into AutoCAD. Your profile says you are using AutoCAD 2018 and AutoDesk has a free import SU file add-on.
    https://help.sketchup.com/en/article/3000115
    Scroll down to 'Creating a 3D model from a photo'
    Other examples on YouTube
    As Rob says you will not get accurate dimensions but you can get a good start.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  1. Back from Sabbatical (and back in the AutoCAD Saddle!)
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 8th Aug 2012, 04:23 am
  2. I'm back... Really never left, but I'm back to posting
    By HyperPics in forum AutoCAD RSS Feeds
    Last Post: 11th Apr 2008, 05:20 pm
  3. picture
    By Niz in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jun 2006, 08:04 pm
