Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    AutoCAD 2011
    Jan 2013
    25
    Default HELP to make 2D drawing
    Hello guys,
    I have a 3D model in Autocad.
    I made a section with sectionplan command and made a layout with the section view.
    I need this view in 2D with lines. every lines in one plan. How can I make it?
    I tried the exportlayout command but then I lost the section.
    I had every lines behind and after the sectionlines...
    Please help if you can!
    (I cant upload the file because it is 11MegaByte)
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    I'm not all that familiar with SectionPlane but what if you were to explode the section? Wouldn't you then end up with lines? A simple example:
    The object at the top is a section created using the SectionPlane command.
    I copied the object then exploded it.
    The middle set of objects turn out to be all lines. I randomly assigned some of them different colors to prove they are individual entities.
    The bottom object is a single hatch entity. Normally this would be erased to reveal the lines. I retained it for demonstration purposes.
    I'm retired now.....not dead. I have a few working brain cells left.
    Full Member
    AutoCAD 2011
    Jan 2013
    25
    Thanks Mark!
    It is not one part 3D model. It is an assembly and I cant copy it. I tried to explode that then the surfaces will delete...
    Is it any chance to create from the layout view a 2D?
    T
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    I'm having some trouble figuring out exactly what you got.
    Have you tried the FLATSHOT command? A view created with flatshot can be exploded into lines as well.
  5. #5
    Full Member
    AutoCAD 2011
    Jan 2013
    25
    Yes, I tried but the same.
    I have everithing behind and front of the section line together....
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Honestly, at this point I have no idea what you are talking about. I've given you two different options and you are telling me neither one suits your purposes.
    Have you tried the combination commands of SolView / SolDraw?
    What is the 3D model of?
    Upload the drawing to a file sharing website like DropBox and post a link to it here. Perhaps after we have looked at it we can discern for ourselves what the problem is and how to arrive at a solution.
  7. #7
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GTX 650 (H)
    520 gb SSD 0/ 1TB 1 (W) 256 GB SSD (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2019
    Sep 2002
    Winston-Salem, NC - USA
    5,693
    I'll send you a PM for your e-mail and I'll add you to a dropbox shared folder. I'll upload an image of the file and we cal take a look.
    F7
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  8. #8
    Full Member
    AutoCAD 2011
    Jan 2013
    25
    Thank you Mark!
    Here is the link:
    https://we.tl/WdwdB5M2FZ
    there are 5 section sign what I need.
    I need only the parts before the section.
    I can delete the red lines behind the section line (they are lines) but allways shows the parts behind the section line as well....
    If you can help please check.
    Thank you
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Parts behind a section would normally be shown as dashed lines wouldn't they? Note what happen when I exploded the section in the simple example I show above.
    I looked at your drawing which I expected to be the 11MB model but isn't. I still cannot fathom what you are trying to accomplish. Perhaps someone else can assist you.
  10. #10
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2019
    Sep 2002
    5,693
    Yeah that drawing has me scratching my head as well. What exactly is it supposed to be?
  1. Help - I can`t make dimensions from this drawing
    By 4RIDERS in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Jun 2015, 11:48 am
  2. How do you make a drawing already done in a ucs, the world ucs?
    By runner041 in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2010, 05:05 pm
  3. Make a drawing look like a sketch?
    By bennyhenry in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2010, 11:37 pm
  4. The best way to make a model from this 2D drawing
    By Lideman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Feb 2010, 07:31 am
  5. How To Make Sure I Am Drawing 1:1
    By iamlegend in forum AutoCAD Beginners' Area
    Last Post: 5th Feb 2009, 11:51 pm
Tags for this Thread
