+ Reply to Thread
Results 1 to 1 of 1
  1. #1
    Full Member benhubel's Avatar
    Computer Details
    benhubel's Computer Details
    Operating System:
    Windows 7
    Discipline
    Manufacture
    benhubel's Discipline Details
    Occupation
    Waterjet Programmer
    Discipline
    Manufacture
    Using
    AutoCAD 2012
    Join Date
    Dec 2015
    Location
    Dallas, Texas
    Posts
    82
    Default Offset polyline trimming
    I am hoping this will be a simple fix, but searching for the answer has turned up nothing.
    If I offset a self-intersecting polyline, it trims the offset anywhere that it crosses the original polyline. I am looking for a way for the offset to continue through self intersections untrimmed. My hope is that the self-trimming is a "feature", and that there is a way to turn it off, perhaps through a system variable or something. If not, the only way I can think to fix it is to write my own custom offset which doesn't sound very efficient.
    ps. Although I'm posting this in the general autocad area, I'm open to solutions that require autolisp. The reason I'm looking for this answer is to be used in an automated routine once I get past this hurdle.
    ***edit***
    I found this thread , but it doesn't give a solution (aside from "use an ancient version on AutoCAD").
    I just now discovered for the first time that I am prone to memory loss.
Similar Threads
  1. lisp for trimming/ breaking a polyline or line
    By piterfun7777 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2015, 11:44 am
  2. Trimming everything outside a closed Polyline
    By Bobzy20 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd May 2013, 10:37 pm
  3. Trimming Polyline 2013
    By Simple153 in forum AutoCAD General
    Last Post: 23rd Oct 2012, 04:30 pm
  4. offset - is there a new variable for clever trimming?
    By designerstuart in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Dec 2011, 08:17 pm
  5. offset polyline
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Dec 2008, 12:49 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
