Results 1 to 2 of 2
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    682
    Default Batch convert to mass elements
    Hi, i'm digging into ACA and face a model with a lot of solids i want to turn into mass elements SEPERATELY. Found a old post without any answer. How can this done?
    Any clue? Thanks
    https://forums.autodesk.com/t5/autod...ch/td-p/423414
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    AutoCAD 2017
    Jul 2015
    682
  1. AutoCAD - Mass Convert DWG To DXF (Batch Convert DWG To DXF) (Mas DWG Convert)
    By kArThIcK hAcKeR in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 27th Mar 2018, 04:22 pm
  2. Mass convert dwg to dxf
    By kArThIcK hAcKeR in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd May 2014, 11:23 am
  3. Smoothing out curved mass elements
    By Alminate in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Jan 2010, 03:56 am
  4. Trimming multiple mass elements?
    By tutt in forum AutoCAD Beginners' Area
    Last Post: 12th Jan 2010, 11:32 am
  5. Mass convert 2006 dwg's to 2000 format.
    By HoustonPhotog in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2006, 02:45 pm
