+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Full Member
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    49
    Embarrassed Is it possible create lisp for dimension?
    Hello everyone,
    I use Qdim for dimensions but I need the totaldim.
    Is it possible to create a lisp?
    with quick dimension. tipical lisp
    Add new lisp
    Thank you
  2. #2
    Senior Member
    Using
    AutoCAD 2016
    Join Date
    Jan 2012
    Posts
    172
    Default
    Why not use "DIMLINEAR" ?
  3. #3
    Full Member
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    49
    Default
    I think it would be very useful to work with this new lisp
    We would have dimension + total dimension.
  4. #4
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,716
    Default
    titoprax yes its possible just have to do it via a lisp recording pick points and run dim twice and 2*offset for dim total. dim pt1 pt2 pt3 pt4 etc dim pt1 ptlast
  5. #5
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,716
    Default
    This is a start needs a vertical option to be added its just for testing needs some extra error checking etc. Maybe a distance offset for dims rather than pick a point. It needs to take into account the 4 sides and directions involved. Uisng a L R U D as 1st pass is one way around the problem.
    Code:
    ; Autodim a number of points in the 4 ortho directions including a total dim.
    ; By Alan H Oct 2017
    (defun c:adim ( / lst x y lst2 pt3 pt)
    (defun AH_units ()
    (SETQ ANGBASEE (GETVAR "ANGBASE"))
    (SETQ ANGDIRR (GETVAR "ANGDIR"))
    (SETQ LUNITSS (GETVAR "LUNITS"))
    (SETQ LUPRECC (GETVAR "LUPREC"))
    (SETQ AUNITSS (GETVAR "AUNITS"))
    (SETQ AUPRECC (GETVAR "AUPREC"))
    (SETVAR "LUNITS" 2)
    (SETVAR "ANGBASE" 0.0)
    (SETVAR "ANGDIR" 1)
    (SETVAR "LUPREC" 0)
    (SETVAR "AUNITS" 0)
    (SETVAR "AUPREC" 0)
    (defun old_AH_units ()
    (SETVAR "LUNITS" lunitss)
    (SETVAR "ANGBASE" angbasee)
    (SETVAR "ANGDIR" angdirr)
    (SETVAR "LUPREC" luprecc)
    (SETVAR "AUNITS" aunitss)
    (SETVAR "AUPREC" auprecc)
    (ah_units)
    (setq lst '())
    (while (setq pt (getpoint "Pick dim points in sequence <Cr> to stop"))
    (setq lst (cons pt lst))
    (setq lenlst (length lst))
    (setq pt3 (getpoint (nth 0 lst) "Pick offset pt"))
    (setq ang (angle (nth 0 lst) pt3))
    (cond
    ((= 0.0 ang)(setq dirrvh "VER" direc "R"))
    ((= (/ pi 2) ang)(setq dirrvh "HOR" direc "U"))
    ((= pi  ang)(setq dirrvh "VER" direc "L"))
    ((= (* pi 1.5) ang)(setq dirrvh "HOR" direc "D"))
    (if (= dirrvh "HOR")
    (setq lst2 (vl-sort lst
    (function (lambda (e1 e2)
    (< (cadr e1) (cadr e2))
    (setq pmax (cadr (nth (- lenlst 1) lst2)))
    (setq pmin (cadr (nth 0 lst2)))
    (if (= direc "U")
    (setq off (- (cadr pt3) pmax))
    (setq off (- (cadr pt3) pmin))
    (setq pt4 (list  (cadr pt3)(+ off (cadr pt3))))
    (if (= dirrvh "VER")
    (< (car e1) (car e2))
    (setq pmax (car (nth (- lenlst 1) lst2)))
    (setq pmin (car (nth 0 lst2)))
    (if (= direc "R")
    (setq off (- (car pt3) pmax))
    (setq off (- (car pt3) pmin))
    (setq pt4 (list (+ off (car pt3))(cadr pt3)))
    (old_AH_units)
    (setq x 0)
    (repeat (- (length lst) 1)
    (command "Dim" dirrvh (nth x lst) (nth  (+ x 1) lst) pt3 "" "exit" )
    (setq x (+ x 1))
    (command "Dim" dirrvh (nth 0 lst) (nth (- (length lst) 1) lst) pt4 "" "exit" )
  6. #6
    Full Member
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    49
    Default
    Yeeaaaaaahh¡¡¡ Thank you Bigal
  7. #7
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,716
    Default
    Have a few ideas for the 4 directions to pick automatically. Worked out how do that so it knows left up etc just debugging code code now.
  8. #8
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,716
    Default
    The code above has been updated and will work for 4 directions.
  9. #9
    Forum Newbie
    Discipline
    Mechanical
    Using
    AutoCAD 2018
    Join Date
    Oct 2017
    Posts
    4
    Default
    My apologies for bumping an older thread, but I didn't see a private message feature. I'm trying to use the program you wrote but don't understand the ending condition, "<Cr> to stop." Is this a keystroke or a text input?
  10. #10
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,716
    Default
    To quote Homer Simpson "where is the any key".
    For us a bit older <Cr> means press Carriage return which on keyboards now is the Enter key. I use this method with pick objects also pick nothing should exit ie a blank spot on your dwg as the getpoint returns a Nil. Pressing Esc will exit but you get an error message.
Similar Threads
  1. How to create rebar dimension lisp in autocad
    By Akech in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Mar 2016, 06:31 am
  2. Create Dimension Style Using Visual Lisp?
    By ksperopoulos in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2016, 07:08 pm
  3. Need help !Use lisp Create text style & dimension style.
    By lucas3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2014, 05:53 pm
  4. dimension style create (plz chk my new lisp & how to improve)
    By autolisp in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2010, 08:01 am
  5. How to create dimension
    By abishop in forum Autodesk Inventor
    Last Post: 29th Oct 2009, 02:09 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
