Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
  1. #11
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Quote Originally Posted by Cad64 View Post
    I think he wants to replace existing solid models with block instances. For example, if he has 100 individual nuts, washers & bolts in his model, he wants to automatically replace all those individual parts with block instances. I don't know how to do that without the aid of a custom lisp routine, but even then, I think it would be quite difficult to precisely replace the solids with block instances, taking into account the exact position, rotation and alignment of each solid.
    This is why it's important to have a game plan before you start building a model. If you know you're going to have repetitive items, like nuts & bolts, create blocks in the beginning. Trying to go back now and replace everything with blocks is going to be a chore and something you will probably have to do manually.
    I am looking for tool similar to that: http://www.cadforum.cz/cadforum_en/s...locks-tip10802
    but without restrictions.
    I've got ready 3d model with 3d solids.
  2. #12
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    I don't care about bolts and nuts, just for plates and RHS's sections
  3. #13
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,149
    And how does that routine restrict you?
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  4. #14
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Quote Originally Posted by steven-g View Post
    The application doesn't support combined 3D solids (3DSolid) created e.g. using boolean operations, only boxes, cylinders and other primitives.
  5. #15
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    688
    Quote Originally Posted by JamesBorubar View Post
    Intressting routine, but i could not get it to work.
    modelled 5 cubes all 1.0 m3 but is doesn't seem to work.
    How does this routine work? What does it calculate to check for equility? (i was thinking : volume and boundingbox?)
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  6. #16
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Quote Originally Posted by halam View Post
    It works, but only with sample drawing Kvadry.DWG ...
  7. #17
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Upload a sample drawing. Create the sample, if needed, to avoid proprietary/intellectual property concerns.
  8. #18
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    I think that I can compare (2) 3D Solids and tell if they are identical geometry, layers, color etc. I cannot tell you where they are located .
    Draw (2) 3D SPHEREs with the same diameter, only different locations.
    Code:
    (defun c:c3d (/ ss e1 e2 d1 d2 c1 c2 rl)
      (while (not e1)
             (princ "\nSelect 2 Entities:   ")
             (and (setq ss (ssget))
                  (= (sslength ss) 2)
                  (setq e1 (ssname ss 0)
                        e2 (ssname ss 1))
                  (not (eq e1 e2))
                  (setq d1 (entget e1)
                        d2 (entget e2))))
      (setq rl (list -1 5 330))
      (foreach g d1
        (if (not (member (car g) rl))
            (setq c1 (cons g c1)))
            (setq c2 (cons g c2))))
      (if (equal c1 c2)
          (alert "SOLIDs Are Indentical")
          (alert "SOLIDs Are NOT Indentical"))
      (prin1))
    Without the location information, I don't know if it could be done. -David
    And I do mean identical. Not rotated, not different elevations etc
    R12 (Dos) - A2K
  9. #19
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    I would just make it a block and locate them manually, just try to make the insertion point of the block something logical for locating.
    Is there a particular relationship between the solids?
    Just post a drawing that shows what is needed, might help with better solutions.
  10. #20
    Full Member
    Multi-disciplinary
    AutoCAD 2017
    Aug 2016
    Poland
    32
    Sorry I was wrong, it works with AutoCad 2015:
  1. exploding blocks with 3d solids not behiving in autocad 2015
    By golfdogz in forum AutoCAD Drawing Management & Output
    Last Post: 5th May 2014, 03:50 am
  2. What do I do to turn wire framed solids into solids
    By cyter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Apr 2011, 11:09 pm
  3. Calculate mass of Solids including ones in blocks.
    By CADkitt in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2010, 02:54 pm
  4. Solids and Blocks
    By AlinOz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Aug 2009, 07:06 am
  5. importing solids into 3dsmax5 - solids coming out see thru?
    By ironman2 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2005, 05:21 am
Tags for this Thread
