Results 1 to 4 of 4
    Forum Newbie
    Construction
    AutoCAD 2010
    Feb 2017
    5
    Default [Plz Help] how to make new object in autocad!!!
    i have 2 picture:
    pic N.1: i select object and press Ctrl +1 ( tad property) show is : "No Selection" ????
    pic N.2 : i copy it and use command Explore -----> in tab property it is : Polyline
    how to make it???by .net or VBA
    i know a little .net and Vba, can i use to make same thing???
    Tks a lot
    P/s: sorry about my English
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,581
    An example for you in lisp it uses the left right up down to draw a pline
    eg R100 U100 L100 C draws a 100 box
    Code:
    ; draw a pline by direction Up Down left or Right use upper or lowercase
    ; by Alan H dec 2015
    ; this version is a metric/decimal version
    ; version 2 depending on request will be a imperial version
    ; 1'8 1/4" input d1.8.25 start with 1.8 = 1'8" then add second fraction ver 3
    ; how to use u123.45 D34.57 R102.6 l53
    (defun ah:left ( / pt2)
    (setq pt2 (polar pt pi (atof (substr ans 2 (- (strlen ans) 1)))))
    (setq pt pt2)
    (command pt2)
    (defun ah:up ( / pt2)
    (setq pt2 (polar pt (/ pi 2.0) (atof (substr ans 2 (- (strlen ans) 1)))))
    (setq pt pt2)
    (command pt2)
    (defun ah:right ( / pt2)
    (setq pt2 (polar pt 0.0 (atof (substr ans 2 (- (strlen ans) 1)))))
    (setq pt pt2)
    (command pt2)
    (defun ah:down ( / pt2)
    (setq pt2 (polar pt (* 1.5 pi) (atof (substr ans 2 (- (strlen ans) 1)))))
    (setq pt pt2)
    (command pt2)
    (defun C:ahpliner ( / pt ans)
    (command "_pline")
    (command (setq pt (getpoint "Pick start point - Enter or C to finish")))
    (while (= (getvar "cmdactive") 1 )
    (setq ans (getstring "Enter L123 U456 R67 D78"))
    (cond ((= ans "")(command ""))
          ((= "L"(strcase (substr ans 1 1)))(ah:left))
          ((= "U"(strcase (substr ans 1 1)))(ah:up))
          ((= "D"(strcase (substr ans 1 1)))(ah:down))
          ((= "R"(strcase (substr ans 1 1)))(ah:right))
          ((= "C"(strcase (substr ans 1 1)))(command "close"))
    ) ;cond
    ) ; while
    Forum Newbie
    Construction
    AutoCAD 2010
    Feb 2017
    5
    tks BIGAL.
    but it's wrong i can draw pline by .net very simple
    i mean make a pline and pline's property show is "no selection"
    Senior Member
    Civil
    Hippe013's Discipline Details
    Survey Crew Chief / Civil Designer
    Civil
    Land Survey / Civil Engineering
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    It is just a bug when you have something selected and you open the properties palette and it says "no selection". You cannot make a pline's property show "no selection".
  1. Make object impenetrable
    By rclose in forum Autodesk Inventor
    Last Post: 12th Oct 2015, 02:35 pm
  2. make one object from many
    By cete in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Jun 2009, 03:13 pm
  3. How to make an object opaque?
    By frostrap in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th May 2008, 01:43 pm
  4. how to make a pop up for an object
    By geoXXL1968 in forum AutoCAD Beginners' Area
    Last Post: 10th Jul 2006, 01:55 am
  5. make an object bigger with same dim.
    By ralph james in forum AutoCAD Drawing Management & Output
    Last Post: 8th Nov 2002, 11:46 pm
