Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    how does it do it automatically? There some point text sequence thing or something?
  2. #12
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    BIGAL ssget is ssgone in LT
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  3. #13
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Understand Steven was waiting confirmation is it LT or Full Autocad ?
    Copy and paste 1st point x y and last point x y to Excel how many bays and use VBA inside Excel to write a script, Steven-g as you have suggested previously its possible to do lots of calcs in excel and just copy the last column created to the command line. When we draw car parks they have set width so with two pts you can work out all the other points.
    Bjenk800 just think about it 50 bays pick two points all done this is about as automatic as it gets.
  4. #14
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    Quote Originally Posted by BIGAL View Post
    Thats what I tried to show in my own clumsy way with that excel file previously, it just uses the row number of excel and performs a calculation on that numer then uses the result to make the script/list.
    You can do exactly the same with just a few coordinates from Autocad and then as you suggest divide the results by 50 to locate each parking bay.
    And yeah lots of calcs I regularly have to leave excel running for half an hour or more when I'm pulling quantities out of drawings.
  5. #15
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Steven are you using VBA inside excel ? Would it not work better to run the same sort of VBA directly inside Autocad ? Or is it one of those things a big job to start from scratch and rewrite it all. Instead of cell for x y you can use direct pt from Autocad.
    donaldo still waiting LT or Autocad 2012 ?
  6. #16
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    if someone knows of a youtube clip explaining whatever you guys are talking about i would be interested. I'm lost.
  7. #17
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    BIGAL yeah that's using VBA and again not available in LT, I do use full Autocad at work but LT privately, the program that runs so long is basically sorting and shuffling data between cells in excel and is honestly the best place for it. I wouldn't know where to start something like that in Autocad, the list of variables would be incredible, in excel I have twice run out of rows, that's a lot of data to keep track of, but I am slowly trying to use VBA in Autocad for other things.
  8. #18
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    No worries steven
    bjenk8100 think of it like this you have LT open and use ID and pick a pt paste to excel look at image, I would use a VBA macro to automate some of the steps. I just copied the highlighted cells to the command line more calculations can be done.
  9. #19
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    oh,
    https://apps.autodesk.com/All/en/Lis...t=&query=excel
    looks pretty close to what you want to do. no point spending all day writing your own scripts.
  10. #20
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    I had a few minutes and checked a real dwg. Bjenk8100 now I have made the spreadsheet I can do as many as I like, The spreadsheet can be vastly improved to take into account an angular answer, using ucs would probably get around it. I appreciate what you posted but where in amongst the 165 answers is one that matches the original request.
    No VBA NO macro's just pure Excel.
  1. adding a comma to numbers in autocad
    By newchurchr in forum AutoCAD Beginners' Area
    Last Post: 11th Feb 2016, 01:17 pm
  2. Adding numbers in a schedule
    By ic_whitehead in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Sep 2013, 10:43 pm
  3. Adding numbers together in text strings
    By BrianTFC in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2012, 03:58 am
  4. Coding Help - Adding numbers to text
    By Piper in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Nov 2010, 09:19 pm
  5. adding numbers to numbers
    By philk in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Feb 2006, 05:45 pm
