Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    Architecture 2016
    Nov 2014
    20
    Default I need an additional LISP lesson
    Hi together,
    I'm looking for a "jump mark" or a "goto-function" but there is no one.
    I need a simplification of my code because I don't want to write the programs e.g.(program 1), (program 2),... twice under each (progn because there are the same.
    (if (/= 0 checkPINstate)
    (requestPIN)
    (if (= checkPIN inputPIN)
    (program 1)
    (program 2)
    (program 1)
    (program 2)
    kind regards
    Bluebird1973
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,522
    There are a lot of different ways to approach this
    Code:
      (while (/= 0 checkPINstate)
             (requestPIN)
             (checkPINstate))
      (program1)
      (program2)
    This will force a correct PIN, leaving only esc as a alternate exit ( probably not the most elegant nor best solution )
    -David
    R12 (Dos) - A2K
    Senior Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    461
    My 2c...
    Code:
    (cond ((and (/= 0 checkpinstate) (requestpin) (= checkpin inputpin)) (program 1) (program 2))
          ((program 1) (program 2))
    Junior Member
    Architecture 2016
    Nov 2014
    20
    Hi David,
    Hi ronjonp,
    Thanks for your try, but it didn't work.
    kind regards
    Bluebird1973
  5. #5
    Senior Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    461
    Quote Originally Posted by Bluebird1973 View Post
    Hi David,
    Hi ronjonp,
    kind regards
    Bluebird1973
    With your example above, (program1) and (program2) will always run so not sure where you're going with this?
    Perhaps:
    Code:
    (cond ;; Pin already validated .. run programs
          ((= 0 checkpinstate) (program 1) (program 2))
          ;; Pin not validated, get the pin, if pin checks out then run programs
          ((and (requestpin) (= checkpin inputpin)) (program 1) (program 2))
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,080
    What if (requestpin) asigns a global variable 'checkpinstate' and then the funciton itself returns nil.
    Another 2c..
    Code:
    (if (member checkpinstate '(nil 0)) (requestpin))
    (cond ( (and checkpinstate (/= 0 checkpinstate)) (program1) (program2) ))
    When requesting for hints, the copy-paste approach doesn't work always with the examples.
  7. #7
    Senior Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    461
    Perhaps:
    Code:
    (cond
      ((= "0" (getenv "checkpinstate")) (program 1) (program 2))
      ;; Pin not validated, get the pin, if pin checks out set the 'checkpinstate' variable then run programs
      ((and (requestpin) (= checkpin inputpin)) (setenv "checkpinstate" "0") (program 1) (program 2))
    Kind of hard to come to a solution when 1/2 of this requires reading minds LOL.
  8. #8
    Junior Member
    Architecture 2016
    Nov 2014
    20
    I found now a solution.
    Code:
       (cond
                   (requestPIN)
                   (cond
                      (/= checkPIN inputPIN)
                          (princ "\nError: bad argument pw")
                          (exit)
       (if (= Prog checkProg)
             (cond
                ((program 1))
                ((program 2))
                ((program 3))
    kind regards
    Bluebird1973
  9. #9
    Senior Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    461
    Code:
       (cond
                   (requestPIN)
                   (cond
                          (exit)
             (cond
                ((program 1))
                ((program 2))
                ((program 3))
    kind regards
    Bluebird1973
    FWIW .. this will accomplish the same thing without a messy exit.
    Code:
    ;; Assumes that your (requestpin) actually returns something
    (if (or (= 0 checkpinstate) (and (requestpin) (/= checkpin inputpin) (= prog checkprog)))
      (progn (program 1) (program 2) (program 3))
  10. #10
    Junior Member
    Architecture 2016
    Nov 2014
    20
    Hi ronjonp,
    Yes, you are right.
    It is really the better way.
    Thank you for the lesson!!!
    kind regards
    Bluebird1973
  1. Rename Layout LISP. Need to add additional. Please Help.
    By tmelancon in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Dec 2015, 02:58 am
  2. How to get this LISP to add an additional 90 degrees to its rotate
    By msirois in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Dec 2015, 08:03 am
  3. Another Lesson Request
    By CADLee in forum Student Project Questions
    Last Post: 10th Jan 2013, 07:58 pm
  4. viiewports...i need a lesson in scale
    By ThatOne in forum AutoCAD General
    Last Post: 6th Sep 2010, 01:50 am
