Results 1 to 2 of 2
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    Default Dimensions disappearing
    Hello,
    I have never had this problem before I started using 3D and multiple viewports in model space. I have no idea if they are even related. I made a simple 3D model and wanted to mess around and make a few viewports in model space so I could dimension on a "top" view and a "front" view in different viewports. I dimensioned in each model space viewport. I went to paper space and froze the ones I didnt need in each of the two paper space viewports. All was fine. Later I went back to model space and some were gone. If i hovered in the area they would highlight but would not stay. Never have seen this. They were all still visible in paper space viewports so annotative was ok. Very weird. Regen and audit did not do anything. Any suggestions would be appreciated. Just a test drawing thankfully.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,086
    Without seeing a drawing we can only guess, but it sounds as though you don't have "view annotative at all scales" turned on in model space (ANNOALLVISIBLE=1)
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  1. Disappearing Dimensions
    By Tonybere in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Mar 2015, 08:44 pm
  2. Disappearing lines and dimensions
    By fohlmann in forum AutoCAD Beginners' Area
    Last Post: 24th Mar 2010, 02:10 pm
  3. Dimensions disappearing behind viewports
    By Yoosetsu in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2009, 09:46 am
  4. Angular dimensions disappearing when plotting
    By DC7 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Apr 2009, 10:48 pm
  5. Dimensions disappearing
    By andycarpenterf1 in forum AutoCAD Drawing Management & Output
    Last Post: 30th Sep 2008, 03:29 pm
