Results 1 to 8 of 8
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    16
    Default How to change size of all text within a block?
    Hi all,
    I am trying to change the size of the text of the 'dimensions' in this drawing. However they are in a block and when you edit the block they are no longer dimensions as it seems they have already been exploded?
    Is there any way to change the size of all the text whilst keeping the justification correct i.e centre above the dim line.
    Thanks for any suggestions.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    What size do you want it to be?
    I suppose you could edit the block, select one piece of MText, use SelectSimilar, then open your Properties palette and change the text size there. Obviously if you make it larger the text will be a lot closer to the dimension line.
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    16
    Wanted to change from 50 to 125. But i have another 20 drawings to do this on :-(
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Please refer back to my first post.
  5. #5
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    16
    Apologies i did not see the second line.
    Thanks this is a good tip and will help me save some time. However it does as you say make the text cut through the 'dim' line instead of sit above. Suppose i am asking too much to keep it above the line whilst making the text bigger?! (i know some people are never happy lol)
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I'm not a miracle worker although I played one on TV once. Maybe if it had been a text style it's possible a work-around could have been generated but it is what it is for the moment. If I think of a way to do it I'll post back.
  7. #7
    Junior Member
    Electrical
    AutoCAD 2013
    May 2017
    16
    It ok cracked it now! I did what you said (selectsimilar) then go to properties and select 'bottom middle' under justify. Then change the height and that sorts it! Thanks for putting me on the right track
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I was just playing with that very same thing myself when I checked back. Well....the credit then is all yours. Glad you got it sorted out and thanks for updating us.
  1. How to change malty Text size please
    By afrazawan in forum AutoCAD Drawing Management & Output
    Last Post: 10th Dec 2013, 06:45 am
  2. Can't change dimension text size
    By Bill T in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2011, 02:33 am
  3. How to change text size
    By sharpooth in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Apr 2010, 07:14 pm
  4. 'Can't seem to get dim text size to change...
    By dpaulku in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jun 2009, 01:19 am
  5. cant change dimension text size
    By b.muqlueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Feb 2008, 03:46 pm
