Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2016
    Oct 2017
    6
    Question importing excel spreadsheet x,y,z points into the spline function
    i'm trying to learn how to import x,y,z points in excel into a spline function in order to not have to manually type the individual x,y,z point for 100's of x,y,z points in excel. i have been unable to find a meaningful and helpful solution so far in any of the forums thus far. any explains of this i found are vague and don't work.
    Forum Newbie
    AutoCAD 2016
    Oct 2017
    6
    i am using AutoCAD 2017 for Mac and not AutoCAD 2016
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,082
    I have moved your thread to the AutoCAD 3D Modelling & Rendering Forum.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,506
    It should be easy using the concatenate function in excel, I would expect you have X Y Z in seperate columns so you would type SPLINE in say D1, D2 would have =concatenate(a2,",",b2,",",c2) which would display x,y,z copy this down for all points, then just copy the D column to the Autocad command line.
    Scroll down in this post its near the bottom a screen grab example, http://www.cadtutor.net/forum/showth...typing-them-in
  5. #5
    Forum Newbie
    AutoCAD 2016
    Oct 2017
    6
    thanks BIGAL!
    i can now copy and paste x,y,z points into the AutoCAD spline function. it works better with the 'control vertices' than the 'fit points' option. it worked well with up to ~20 x,y,z points when i was pasting them into the spline drawing function.
    for those who are Mac users, it is 'command-v' for pasting and not the Windows 'control-v' used in the examples on the forum. that was the main problem i had in getting the copy and paste of x,y,z data points into the drawing function to work.
  6. #6
    Forum Newbie
    AutoCAD 2016
    Oct 2017
    6
    Default copy and paste excel x,y,z ponts into the spline function
    i updated to autocad 2018 from 2017. i can no longer copy and paste more than 1 excel spreadsheet x,y,z data point into the spline function at a time. before i updated to 2018, i could copy and paste ~20 x,y,z points at a time. does someone have any thoughts on why i can only copy and paste 1 x,y,z point at a time into the spline function after my updating of autocad 2018.
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,506
    Is the 1st paste working fully, sounds like its getting stuck expecting more, press esc a couple of times before next paste. You could join 20 splines into one column or paste to notepad or mac equivalent, you just need 1 blank line between each spline start, the blank line is like press enter to end command. Then save as a script file .scr, use script to run.
  8. #8
    Forum Newbie
    AutoCAD 2016
    Oct 2017
    6
    just a reminder i'm now using autocad 2018 for Mac of which i upgraded from autocad 2017 for mac.
    when i 'command-v' to paste the column of x,y,z points it only puts the second to the last x,y,z point on the stack of last commands and the last x,y,z point on the command line. when i hit 'enter' it gives me an 'unknown' command error. as in my previous posts, after your help, i was able to copy and paste around 20 x,y,z points with which all the points where listed in the command line stack. when i was finished i just hit enter to close.
  9. #9
    Forum Newbie
    AutoCAD 2016
    Oct 2017
    6
    the last post may have appeared to state i can now copy more than one x,y,z point into the spline function at a time.
    it still doesn't copy any more points after i tried your post BIGA on march 31st.
  10. #10
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,506
    Just did a check https://www.autodesk.com/shortcuts/autocad-for-mac#S-U
    And script is supported so as I suggested make a script file with multiple spline entry's you should just need 1 blank line bewteen for them to work.
    Code:
    line
    0,0
    1,0
    1,1
    0,1
    c
    line
    10,10
    20,10
    20,20
    10,20
    c
    line
  1. Inserting Excel spreadsheet
    By Franny in forum AutoCAD Beginners' Area
    Last Post: 23rd May 2017, 03:28 pm
  2. Importing Excel spreadsheet in autocad 2010
    By caby33 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2011, 02:51 pm
  3. Control points of spline to excel
    By karayelh in forum AutoCAD General
    Last Post: 14th Oct 2007, 07:05 am
  4. Importing Excel Spreadsheet
    By CADken in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jun 2007, 07:52 pm
