Steven P Posted October 18, 2017 Share Posted October 18, 2017 Good morning, I hope the title says it all. How do you force a LISP routine to run last when a drawing is opened? I have a LISP with a few commands in it which run when the drawing opens - things like personalising my workspace (I'll get to that in a minute). The company has written an interface with AutoCAD to another piece of software and that puts in what they consider to be the ideal set up. So when the drawing loads my bit runs, it sets up my CAD as I want it, then their interface loads and sets it all up as they want it. I then have to reset it to how I want it again.... What I want to do is change the order around at AutoCAD start up - their set up and then run my LISP. Is there an easy way to specify "Run this bit last" Our company has 'agile working' - I could be on any machine anywhere if needed. I think using a LISP routine is the quickest way to set things up how I want each morning if I am not at my usual desk (Appload - select file - run lisp - job done ) Thanks. Quote Link to comment Share on other sites More sharing options...
dan113 Posted October 18, 2017 Share Posted October 18, 2017 Your looking at implementing something like the following as far as I can tell. This will live in your acaddoc file. (Defun s::startup (/);Your lisp here)[/Code] Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
dan113 Posted October 18, 2017 Share Posted October 18, 2017 Also there is this http://www.cadtutor.net/forum/showthread.php?p=692302 Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
rlx Posted October 18, 2017 Share Posted October 18, 2017 (edited) Depends on how well you get along with your admin... it would be possible to have a lisp file with your own preferences in it and in the company acad.lsp or acaddoc file , via s::startup check for user login name and load user preferences. Or , have your own acad(doc).lsp file and put it first in your search or support path. But this can only work if you can edit your profile. Or create a shortcut to start autocad with /p option and place your lisp files in your network / mydocuments folder. gr. rlx Edited October 18, 2017 by rlx Quote Link to comment Share on other sites More sharing options...
Aftertouch Posted October 18, 2017 Share Posted October 18, 2017 I prefer to use the APPLOAD Startup content. :-) Save for a specific user Quote Link to comment Share on other sites More sharing options...
rlx Posted October 18, 2017 Share Posted October 18, 2017 and if you like to read much : http://www.cadtutor.net/forum/showthread.php?56187-Appload-Startup-suite-Problems. :-) gr.Rlx Quote Link to comment Share on other sites More sharing options...
Steven P Posted October 18, 2017 Author Share Posted October 18, 2017 Thanks so far, I'll try the s:startup thing and see how that goes - I have tried some of the other ideas so will give that a go. Thanks Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 18, 2017 Share Posted October 18, 2017 I use an *.mnl file to load stuff at startup ( assuming your tools are loading some sort of cui\mns ) Quote Link to comment Share on other sites More sharing options...
