Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    my attempt have some fun with command call, but may need to
    consider osmode angdir mirrtext etc..
    Code:
    ;; Make Angle Readable by: ymg
    (defun MakeReadable (a)
      (setq a (rem (+ a pi pi) (+ pi pi)))
      (rem (if (< (* pi 0.5) a (* pi 1.5))
    	 (+ a pi)
    	 a
           (+ pi pi)
     (defun _mirror (x / en ie) ;*global variable= s & ip
     ;simply calling standard command "mirror" to manipulate or flip the reference annotation
        (cons 'progn
    	  (list	(cons 'setq '(ie 0))
    		(cons 'repeat
    		      (list (sslength s)
    			    (cons 'vl-cmdf
    				  (list	"_.mirror"
    					'(setq en (ssname s ie))
    					(cons 'list ip)
    					(cons 'polar (list (cons 'list ip) x 1.0))
    					"Y"
    			    (cons 'setq '(ie (1+ ie)))
        ) ;_ end of defun
     (defun delta (p1 p2 ip / xy id dxy s i a l e)
     ;hanhphuc
          (setq xy     '((p) (list (car p) (cadr p)))
    	    id	(mapcar	''((x) (equal x (apply 'mapcar (cons '>= (mapcar 'xy (list p2 p1))))))
    			'((T T) (nil T) (nil nil) (T nil))
    	    dxy	(mapcar '- p1 p2)
    	    s	(apply ''((txh pt dX dY / ss next ro yd p)
    			  (setvar 'osmode 0)
    			  (setq
    			   yd
    			   (getvar 'ucsydir)
    			   ro
    			   (MakeReadable
    			    (if
    			     (equal (car yd) 0.0 1e-10)
    			     0.0
    			     (atan (/ (car yd) (cadr yd)))
     ; Draw arrow by standard command: PLINE
    			  (vl-cmdf
    			   "_PLINE"
    			   (list (car pt) (+ (cadr pt) (* 2. txh)))
    			   "w"
    			   0.0
    			   (* 0.3 txh)
    			   (list (car pt) (+ (cadr pt) txh))
    			   "w"
    			   0.0
    			   0.0
    			   pt
    			   "w"
    			   0.0
    			   0.0
    			   (list (+ (car pt) txh) (cadr pt))
    			   "w"
    			   (* 0.3 txh)
    			   0.0
    			   (list (+ (car pt) (* 2. txh)) (cadr pt))
    			   ) ; command
    			  (setq next (ssadd))
    			  (foreach
    			   ss
    			   (vl-list*
    			    (entlast)
    			    (mapcar
    			     ''((a b c d)
    				(entmakex
    				 (mapcar
    				  'cons
    				  '(0 1 8 10 11 40 50 62 72 73)
    				  (list "TEXT" a "DIFF" (setq p (polar (trans pt 1 0) (- b ro) c)) p txh (- d ro) 256 1 2)
    			     (list dY dX)
    			     (list  (* pi 0.5) 0.)
    			     (list (* 4.0 txh) (* 4.0 txh))
    			     (list (* pi 0.5) 0.0)
    			     ) ; mapcar
    			    ) ; vl-list*
    			   (ssadd ss next)
    			  next
    		       (vl-list* (getvar 'textsize)
    				 ip
    				 (mapcar ''((f) (rtos (abs (* (f dxy) 1000.)) 2 0)) (list car cadr))
          (eval (cons 'cond
    		  (vl-list* (list (nth 0 id) T)
    			    (mapcar ''((a b)
    				       (list
    					(setq i (nth a id))
    					(_mirror b)
    					(if
    					 (and i (nth 2 id))
    					 (_mirror (* pi 0.5))
    				    '(1 2 3)
    				    (list (* pi 0.5) 0.0 pi)
    	    ) ;eval
         (repeat (setq i (sslength s))
        (setq e (ssname s (setq i (1- i)))
    	  l (entget e)
    	  a (cdr (assoc 50 l))
        (if	(assoc 1 l)
          (entmod (subst (cons 50 (MakeReadable a)) (assoc 50 l) l))
        ) ;repeat
    (defun c:test (/ p1 p2 p3 )
      (terpri)
      (while (and (setq p1 (getpoint "\rTheoretical point..       "))
    	      (setq p2 (getpoint p1 "\rActual point..            "))
    	      (setq p3 (getpoint p2 "\rPlacing arrow..           "))
        (delta p1 p2 p3)
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  2. #12
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    892
    Another:
    Code:
    (defun c:foo (/ _text d p1 p2 s)
      (defun _text (p h s)
        (entmakex (list '(0 . "TEXT")
    		    '(100 . "AcDbEntity")
    		    '(67 . 0)
    		    '(62 . 1)
    		    '(8 . "text")
    		    '(100 . "AcDbText")
    		    (cons 10 p)
    		    (cons 40
    			  (if (> (getvar 'dimscale) 0)
    			    (* h (getvar 'dimscale))
    			    h
    		    (cons 1 (vl-princ-to-string s))
    		    '(50 . 0.0)
    		    '(41 . 1.0)
    		    '(51 . 0.0)
    		    '(7 . "Standard")
    		    '(71 . 0)
    		    '(72 . 1)
    		    (cons 11 p)
    		    '(100 . "AcDbText")
    		    '(73 . 2)
      (if (setq s (ssget '((0 . "point"))))
        (progn (setq s (mapcar '(lambda (x) (cdr (assoc 10 (entget x))))
    			   (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
    		 s (vl-sort s '(lambda (a b) (< (cadr a) (cadr b))))
    	   (while (cadr s)
    	     (setq p1 (car s))
    	     (setq
    	       p2 (car (vl-sort (setq s (cdr s)) '(lambda (a b) (< (distance p1 a) (distance p1 b)))))
    	     (setq d (mapcar 'abs (mapcar '- p1 p2)))
    	     (entmakex (list '(0 . "LWPOLYLINE")
    			     '(67 . 0)
    			     '(62 . 8)
    			     '(8 . "difference")
    			     '(100 . "AcDbPolyline")
    			     '(90 . 3)
    			     (cons 10 p1)
    			     (cons 10 (list (car p2) (cadr p1)))
    			     (cons 10 p2)
    	     (_text p1 0.1 (car d))
    	     (_text p2 0.1 (cadr d))
    	     (setq s (vl-remove p2 s))
  3. #13
    Junior Member
    Construction
    AutoCAD 2018
    Oct 2017
    17
    Quote Originally Posted by hanhphuc View Post
    Code:
    	 (+ a pi)
    	 a
           (+ pi pi)
        (cons 'progn
    		(cons 'repeat
    		      (list (sslength s)
    			    (cons 'vl-cmdf
    				  (list	"_.mirror"
    					(cons 'list ip)
    					"Y"
        ) ;_ end of defun
     ;hanhphuc
    			  (setvar 'osmode 0)
    			  (setq
    			   yd
    			   (getvar 'ucsydir)
    			   ro
    			   (MakeReadable
    			    (if
    			     0.0
    			  (vl-cmdf
    			   "_PLINE"
    			   "w"
    			   0.0
    			   (* 0.3 txh)
    			   "w"
    			   0.0
    			   0.0
    			   pt
    			   "w"
    			   0.0
    			   0.0
    			   "w"
    			   (* 0.3 txh)
    			   0.0
    			   ) ; command
    			  (setq next (ssadd))
    			  (foreach
    			   ss
    			   (vl-list*
    			    (entlast)
    			    (mapcar
    			     ''((a b c d)
    				(entmakex
    				 (mapcar
    				  'cons
    			     (list dY dX)
    			     ) ; mapcar
    			    ) ; vl-list*
    			   (ssadd ss next)
    			  next
    				 ip
          (eval (cons 'cond
    			    (mapcar ''((a b)
    				       (list
    					(setq i (nth a id))
    					(_mirror b)
    					(if
    					 (and i (nth 2 id))
    				    '(1 2 3)
    	    ) ;eval
    	  l (entget e)
        (if	(assoc 1 l)
        ) ;repeat
      (terpri)
        (delta p1 p2 p3)
    Hi,
    This is olmosta done but, is it possible edit code like this: activ osnap stay ON and number is always same direction!
    Best,
    Margus
  1. Theoretical Sharp Corner Dimension Placement
    By gbradley in forum Autodesk Inventor
    Last Post: 23rd Jul 2014, 09:43 pm
  2. Plot Actual Size
    By magic-chef in forum AutoCAD Drawing Management & Output
    Last Post: 1st Dec 2008, 04:09 pm
  3. Fonts that use an actual Ampersand (&)?
    By RhoadBlock in forum AutoCAD Beginners' Area
    Last Post: 21st Jul 2008, 06:15 pm
  4. dimensioning a theoretical sharp corner
    By Dazed and Confused in forum AutoCAD Drawing Management & Output
    Last Post: 1st Feb 2005, 12:45 am
  5. Renders from actual photos
    By hyposmurf in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Apr 2004, 12:17 am
