Results 1 to 4 of 4
    Full Member
    dal-designs's Computer Details
    Windows 7
    HP Compaq Elite 8300 SFF
    Construction
    dal-designs's Discipline Details
    Designer in Oil and Gas Industry
    Construction
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    Angry Title Block Isn't Fitting!
    I have an odd issue with AutoCAD 2014.
    I have two different files which should be identical when I go to plot- exact same xref'ed title block, same paper size set, same plot style, same output (dwg to pdf in this case). This particular title block is set to plot properly at 1:1 paperspace on Arch D 24x36 by window, with center the plot selected. Sure, I could fit to paper, but then everything would be a tiny bit out of scale.
    I've triple-checked all of these settings between the two files; I even changed drawing units to mm temporarily and measured both title blocks in paper space to make sure they were the exact same size. However, in one file the title block doesn't fit - both sides hang off the paper space by a tiny bit.
    I can't think of what variable I'm overlooking that may be causing this. The outputs should be exactly the same, but one file refuses to play nice and fit the whole title block to the plot area!
    EDIT: I think I know what the problem is, but not how to fix it. See attached image. Basically, I need to get the intersection of the dashed lines to the center of the red circle (follow the blue arrow). That's how the correct file looks when it plots.
    Last edited by dal-designs; 20th Oct 2017 at 05:02 am. Reason: Additional relevant information
    Sucking at something is the first step to being kinda good at it
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,947
    Could you post the .dwgs that do this? All we need is the part that doesn't match up when plotted, remove any proprietary information if needed.
    Are you plotting extents? Perhaps an image of the plot setting for each.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,131
    Like SLW210 I use two points Window and centered not extents this solves most problems of title block moved a little bit. The points are +- 6mm from title block.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    In paper size list, has somebody switched that one drawing off of ARCH D EXPAND or FULL BLEED back to standard ARCH D?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Block from title block suddenly dissapered
    By alexwilmacir in forum AutoCAD Drawing Management & Output
    Last Post: 30th Mar 2015, 09:26 pm
  2. Attribute in title block exists in BLock Editor but not in Project.
    By Pawnsurfer in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2015, 09:10 pm
  3. Replies: 2
    Last Post: 14th Nov 2014, 01:56 pm
  4. link title of file to the title block inside
    By 19cruthik68 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2012, 09:25 am
  5. Title Block as Block not Xref (ProjectWise))
    By Wigman in forum CAD Management
    Last Post: 1st Mar 2012, 11:17 am
Tags for this Thread
