Results 1 to 5 of 5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    Default Turn off Xref snapping
    hi
    i have very lazzy xref that i want to redraw,
    is there a way to turn off snapping to that xref? its dwg
    Thanks
    S
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Not without turning off OSnaps entirely.
    Drafting is a breeze.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    If you have a command active F3 suppresses object snaps. It's the best i've been able to come up with.
    You can press and hold F3 while cursoring over the xref with an active command, like Pline, then let it go when you're ready to snap, but that can be a bit tedious.
    Now, if your attachment is a pdf, then there is a button on the xref ribbon to turn snaps on or off in the pdf, but there is not one for an attached dwg. The button may not be there at all in 2010, don't know.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,200
    I wouldn't typically recommend doing this, but if you want to disable snapping to your xref, put it on layer Defpoints and then freeze layer 0. This will make the xref unselectable and you won't be able to snap to it.
    It is not good practice to put anything on layer Defpoints though, so I only mention this as a temporary workaround. Once you're finished, thaw layer 0 and move your xref off the Defpoints layer.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    It's not bad practice if the effects are intended.
    It's only not recommended now, because there is another way to have non-plot layers, it once was standard operating procedure. I still run across lots of drawings with Viewports on Defpoints, some aren't that old, either.
  1. ISO lisp to turn off layers by picking a xref first
    By iconeo in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jul 2017, 03:54 am
  2. Line snapping is not snapping to correct area - need help
    By Joestradamus in forum Civil 3D & LDD
    Last Post: 26th Feb 2013, 05:23 pm
  3. Turn on/off Xref layers
    By LISP2LEARN in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2011, 02:51 pm
  4. random veiwports turn off as i turn others on
    By mvrcad in forum AutoCAD Drawing Management & Output
    Last Post: 20th Apr 2011, 11:55 pm
  5. If layer is on turn it off if off turn it on
    By TheZman in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Oct 2010, 05:09 pm
