Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,541
    Default XREF PDF Files ?
    Here's a new 1 on me.
    My client had an existing building surveyed. The drawings from the renovation were hand drawn from the 90's. So they had those scanned into pdf. Mostly wall lines, windows and doors
    The architect ( who I will contact next week ) looks to have somehow xrefed these pdf files as back grounds.
    I haven't found a way to get DWGTrue view ( 2016 ) change the paths. ( I'm sure that is operator error )
    DWG Convert has no clue how to handle it
    I wondering if I will have to trace the pdf lines ?
    Have any of you guys run into this ?
    -David
    R12 (Dos) - A2K
    AutoCAD 2013
    Nov 2011
    5,985
    I would assume that they were Inserted as PDF Underlays?
    I also expect you to have to trace them, unless they were done on one of the very latest versions which may have the ability to convert the PDF linework into Autocad objects.
    If you click on one, what sort of object does it come up as in Properties?
    You might try downloading DWG Trueview 2017, as I seem to recall that may be the version with that magical PDF conversion voodoo.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,075
    I have had problems with x-ref paths with DWG TrueView in the past, but if all files are in the same folder, then the x-refs are picked up when the drawing is opened, despite the pathing.
    I am presuming that you were sent all the pdfs which are x-reffed.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,541
    Quote Originally Posted by eldon View Post
    All but 1 pdf were included.
    All files are in a single local drive directory. The xref path strings are like a mile long and point to a network drive. Oh the fun ~!
    Thanks -David
    R12 (Dos) - A2K
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,541
    Quote Originally Posted by Dadgad View Post
    I had no idea you could xref a pdf. They show in a xref properties box. But the paths are not editable.
    I have trueview 2018. I'll try that to convert the monster. :fingers_crossed_smiley ( if there were 1 )
    Thanks! -David
    R12 (Dos) - A2K
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    When you use PDFATTACH they are in the Xref list, thats the way we do it.
    Have you tried putting xref's in same spot as your dwg this gets around the can not find when using xref DWG's no re-pathing required.
  7. #7
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    2 things. First, David, "you had no idea pdf could be xrefed"? That is like my most popular xrefs. Second, there are programs that will trace the pdf for you. Cost money though.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,541
    PDFATTACH - WOW talk about mixing oil and water !
    I did open the pdf, used 'copy full file name' option in PDF-XChange Editor Pro, pasted into 'found at' field in the xref dialog box.
    What a horrible way to provide existing site survey drawings ! Hell the wall lines are 3" thick ! This is no way to provide an accurate plan for a remodel / renovation.
    A logo ? Maybe. Construction documents ? Never
    Rant off ( for now )
    -David
    R12 (Dos) - A2K
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,075
    I expect that you have found it by now, but when a drawing is opened in DWG TrueView 2018, the external Reference Palette opens up. One can choose a new path for the xref files.
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,541
    I didn't work with pdf files ?
    I had convert the main dwg to 2012 and open it with full acad. -David
    R12 (Dos) - A2K
  1. Xref file attached to which which files
    By sivapathasunderam in forum AutoCAD Drawing Management & Output
    Last Post: 9th Mar 2016, 02:10 pm
  2. Replace old xref files with a set of new xref files
    By SimonC in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2013, 11:29 am
  3. Error files with XREF : HELP !
    By ruchiarch in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Jul 2009, 08:08 am
  4. xref files
    By ralph in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2008, 12:39 am
  5. xref's to dxf files
    By Jon in forum AutoCAD Drawing Management & Output
    Last Post: 4th Nov 2003, 10:52 pm
