+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Senior Member
    Discipline
    Civil
    Aftertouch's Discipline Details
    Discipline
    Civil
    Details
    Engineer
    Using
    AutoCAD 2017
    Join Date
    Jul 2016
    Location
    Netherlands
    Posts
    259
    Default
    In the insert Tab you can import a PDf as a block.
  2. #12
    Forum Deity Dana W's Avatar
    Computer Details
    Dana W's Computer Details
    Operating System:
    Windows 8 64 bit
    Computer:
    Dell XPS ONE 2710
    Motherboard:
    Dunno
    CPU:
    Intel I-5 3330S @ 2.7 Ghz
    RAM:
    6 Gb
    Graphics:
    On board barely adequate
    Primary Storage:
    1 Terrabyte
    Secondary Storage:
    1 Terrabyte external
    Monitor:
    All in one 27" touch & pen
    Discipline
    Construction
    Dana W's Discipline Details
    Occupation
    Architectural Millwork Designer/Draftsman
    Discipline
    Construction
    Details
    Custom commercial millwork.
    Using
    AutoCAD LT 2018
    Join Date
    Feb 2010
    Location
    Oviedo, Florida
    Posts
    4,727
    Default
    Is there no browse button available when you click the xref name in the Saved Path line of the xref manager window?
    IF, and it's a big IF. If the pdf was created in CAD as a vector pdf, there is a button on the xref ribbon to enable snaps in the pdf. That makes tracing them easier. I also reduce the fade to 50% so I can see the snap icons. With those fat (doubled up close) lines there will be a lot of snaps hiding just near enough to the one you want to be a huge bother.
    The pdf xref can be scaled by reference if there are dimensions, or scaled according to the drawing title scale IF (another big one) the pdf image was generated full size from AutoCad rather than being nearly useless raster images.
    I have had issues drawing on top of pdf's and then selecting the drawn geometry. The pdf seems to select no matter whether I window left or right. Lock the layer you have the pdf on to avoid hassles like only finding this out after moving or copying the pdf somewhere it will be disliked immensely.
    This is day to day business for me. I've attached multiple pdf's to every single cabinetry/millwork drawing I have done for two years now. It's become like breathing (through a straw, but breathing)
    When I used to freelance I would tell my clients to give me CAD files for xrefs or lots more money and lots more time.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  3. #13
    Forum Deity David Bethel's Avatar
    Discipline
    Multi-disciplinary
    David Bethel's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Commercial Food Service
    Using
    AutoCAD pre 2000
    Join Date
    Dec 2003
    Location
    Newport News, Virginia
    Posts
    2,541
    Default
    The pdfs were generated from scans of hand drawn architectural drawings from the 1990s renovation of the property.
    I doubt they be useful for any thing other than a pretty picture. Thanks. -David
    R12 (Dos) - A2K
  4. #14
    Computer Details
    Operating System:
    Windows 8 64 bit
    Computer:
    Dell XPS ONE 2710
    Motherboard:
    Dunno
    CPU:
    RAM:
    6 Gb
    Graphics:
    Primary Storage:
    1 Terrabyte
    Secondary Storage:
    Monitor:
    Discipline
    Construction
    Occupation
    Discipline
    Construction
    Details
    Using
    AutoCAD LT 2018
    Join Date
    Feb 2010
    Location
    Oviedo, Florida
    Posts
    4,727
    Default
    No snaps in them thangs. And any conversion program that claims to handle rasters will turn almost every little contiguous pixel group into a line. The best you can get out of them is to scale by reference, and use them as just that, a reference.
  5. #15
    Super Member bjenk8100's Avatar
    Computer Details
    bjenk8100's Computer Details
    Operating System:
    windows 8 64 bit
    Discipline
    Construction
    Using
    AutoCAD 2018
    Join Date
    Sep 2009
    Posts
    622
    Default
    i dunno if this helps but bluebeam is designed for arch/eng industries.
Similar Threads
  1. Xref file attached to which which files
    By sivapathasunderam in forum AutoCAD Drawing Management & Output
    Last Post: 9th Mar 2016, 02:10 pm
  2. Replace old xref files with a set of new xref files
    By SimonC in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2013, 11:29 am
  3. Error files with XREF : HELP !
    By ruchiarch in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Jul 2009, 08:08 am
  4. xref files
    By ralph in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2008, 12:39 am
  5. xref's to dxf files
    By Jon in forum AutoCAD Drawing Management & Output
    Last Post: 4th Nov 2003, 10:52 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
