Results 1 to 7 of 7
    Forum Newbie
    Surveying
    AutoCAD 2017
    Oct 2017
    4
    Default help with macro command
    Hi. Can someone please help me, tell me or explain to me how to create new layer with macro.
    I want define a new button which when I push it will make new layer and ask me for define name and colour of new layer.
    I'm kind a new to this.
    I found only this code using LISP. But I want macro for button.
    Code:
    (defun c:SetLayer  (/ name col)
      (if (setq name (getstring t "New layer name: "))
        (if (tblsearch "LAYER" name)
          (progn (prompt "Layer already exists, set as current.") (setvar "CLayer" name))
          (if (setq col (acad_colordlg 7 nil))
            (progn (entmake (list '(0 . "LAYER")
                                  '(100 . "AcDbSymbolTableRecord")
                                  '(100 . "AcDbLayerTableRecord")
                                  '(70 . 0)
                                  (cons 2 name)
                                  (cons 62 col)))
                   (prompt "Layer created and set current.")
                   (setvar "CLayer" name)))))
      (princ))
    Thank you for your time guys and have a nice day
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,148
    Add something like a DCL for the questions see below for getvals3.lsp
    Code:
    ; can add linetype if required
    (defun c:SetLayer  (  / name col )
    (if (not AH:Getval3)(Load "getval3"))
    (ah:getval3 "Enter layer name"12 10 "New" "Enter Colour" 5 4 "3" "Enter Linetype"12 10 "Continuous")
    (setq name val1 col val2)
                                  '(70 . 0)
                                  (cons 2 name)
                                  (cons 62 col)))
    ; add linetype here
      (princ))
    Forum Newbie
    Surveying
    AutoCAD 2017
    Oct 2017
    4
    Thank you BIGAL but I want know how to do that in macro.
    I mean how to write it here.
    Sorry for my english
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,148
    ^c^c^p(if (not c:setlayer)(Load "setlayer"))(C:setlayer)
  5. #5
    Forum Newbie
    Surveying
    AutoCAD 2017
    Oct 2017
    4
    Thank you very much :-) it is great
  6. #6
    Forum Newbie
    Surveying
    AutoCAD 2017
    Oct 2017
    4
    Is there any way how to write it all as macro and not only as reference link for that command? Thank you for your time
  7. #7
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    Untested:
    Code:
    ^C^C-LA M \C
    About Pausing Macros for User Input: http://help.autodesk.com/view/OARX/2...A-00F8986611F2
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  1. Macro - Unknown command for any multiple command
    By p0peye in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 2nd Nov 2013, 10:27 am
  2. SELECT in macro won't stay selected!!!! How to hide Macro in command line aswell?
    By jamesfear in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 31st Jul 2012, 02:23 am
  3. Macro command in command prompts shortcut?
    By Benjo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Feb 2011, 04:11 am
  4. Macro command in command prompts shortcut?
    By Benjo in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 8th Feb 2011, 05:57 pm
  5. Create a Command to run macro from command line
    By Andresig in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Sep 2010, 09:16 pm
Tags for this Thread
