Results 1 to 7 of 7
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Question CAD - plan and side view
    I'm just trying to learn a little bit about CAD myself, therefore this is a fairly basic question.
    If drawing up a plan view (bottom of the attached image) with a corresponding side view directly, precisely how would you go about putting in the vertical lines connecting the two so that these are in precisely the correct place.
    Do you simply draw the horizontal line at the top (longer than required), then switch on the required OSNAPS?
    Which OSNAPS would you have switched on?
    Thanks for any help.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Why would you draw the horizontal line longer than the width of the object?
    As for the OSnaps at the minimum I'd enable endpoint, intersection and center.
    Way back when...we were taught to draw the top, front then side views in that order. Any basic technical drawing/drafting book will have a chapter devoted entirely to orthographic projection.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,581
    See my answers in bold below.
    Quote Originally Posted by L-P View Post
    There are multiple ways to get there, none really more correct than the other although some will probably argue. So yes, for now, draw the horizontal line above, draw lines to that, start trimming, etc to edit it to what you need.
    A way to do this so you don't have lines to trim later is to use Object Tracking, you can hover over a point then move the cursor up and pick a point on the line above, for example. Look at help or online for videos showing this technique.
    I would use, ENDP, QUA, CEN, PERP, INT
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Full Member
    AutoCAD 2012
    Apr 2015
    48
    Object snap tracking is the way forward. I wouldn't get into the habit of drawing lines and tidying up later when there is no need.
    Most of the 'cad' people I work with turn every snap on and that's their setup. There is a place for each snap point but that's what temp overrides are for.
    When we set someone new on that needs training they get sent to me and I set them all up the same. I show them how to change the settings they normally end up with how I set them up. I played with osmode for years and finally settled on osmode 239.
    Sent from my Pixel XL using Tapatalk
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    I simply make a copy of the top view, rotate it -90 deg (angle measurement set to relative) and place it above where I want to draw my side view. It's a modified version of Orthographic projection which eliminates the 45 deg diagonal line, and at the same time shows the purpose for the line. Then I project lines down from the top view and over from the front view. Traditional Ortho projection is fine, and necessary for paper drafting but when you have a computer where Erase doesn't dig holes in your paper, take advantage.
    Besides, using traditional ortho projection on a complicated object, like an office break room jammed full of cabinets, is extremely 'projection line' intense, and it's easy to lose your place.
    Another thing; one does not have to leave ALL the projection lines in place nor do you have to lay them ALL in at one time. That's another adaptation to the computer.
    Back in paper days, I'd draw in the projection lines with .3mm 4H lead, and just leave them on the paper. Then lay in the objects with 0.7mm 2H or 0.5mm 3H. The projection lines gave the drawing a nice Techy look all faded in the background when run through the diazo machine. I could burn them off of the prints with the speed knob if I needed to.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    Here's the simplest example of orthographic projection I have. It's a 6" long piece of 2x4. The orange and light gray lines are temporary. The orange line MUST be at 45 deg.
  7. #7
    Super Member nukecad's Avatar
    nukecad's Computer Details
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    NW Cumbria (English Lake District)
    703
    Check the Autocad XLINE command.
    https://knowledge.autodesk.com/suppo...992C1-htm.html
    http://autocadtip.com/xline-command-in-autocad.html
    *** Out of Beer Error ->-> Recovering Memory***
  1. How to draw side view knowing only top and front view?
    By khoshravan in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Dec 2016, 08:41 am
  2. Ellipse right side view?
    By Sengna in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2015, 06:11 pm
  3. Can visual styles work like model view, but in plan view?
    By Cad Monkey 2 in forum Architecture & ADT
    Last Post: 16th Jun 2011, 02:03 am
  4. Replies: 9
    Last Post: 15th Jul 2010, 03:15 am
  5. View Layouts side by side?
    By comcu in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Aug 2008, 06:03 pm
