Results 1 to 6 of 6
Thread: Viewing arcs
    Forum Newbie
    AutoCAD 2017
    Oct 2017
    3
    Default Viewing arcs
    I have drawn some arcs to create a long ribbon-shaped line and every time I re-open the drawing the curbes of those arcs are changed to straight lines with corners. How do I get the curves back?
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,591
    Arcs appear as straight lines, circles appear as polygons
    Common causes:
    1. VIEWRES is set too low (WHIPARC has to be off) , set it to 5000.
    2. SHADEMODE has been set to other than 2D
    3. WHIPARC is set to 0. (Viewres will have no effect when whiparc is set to 1)
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,417
    The theory behind the straights, in an attempt to speed up graphics lots of software uses a simple trick of showing curves as multiple straights. You will often find in Autocad an arc will not touch a line but an intersection will reveal true point. Like rkent you can control the straights the bigger the number the trade off is graphics speed.
    I am sure like lots here we just live with it and do RE when an improved image is required.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Quote Originally Posted by Kristen N View Post
    ............How do I get the curves back?
    The quick answer is use the command REGEN first.
  5. #5
    Forum Newbie
    AutoCAD 2017
    Oct 2017
    3
    Smile
    Thank you rkent! Very helpful.
    Quote Originally Posted by rkent View Post
    Common causes:
  6. #6
    Forum Newbie
    AutoCAD 2017
    Oct 2017
    3
    Thanks eldon, that worked!
  1. arcs converted into eliptical arcs
    By sarovna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Jul 2015, 01:15 pm
  2. Arcs tangent to two other arcs/circles
    By andymccallum in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Sep 2014, 12:47 pm
  3. Viewing 3D Text
    By KevinMcDonagh in forum AutoCAD General
    Last Post: 5th Aug 2014, 01:40 pm
  4. adding windows to arcs and misshappen arcs?
    By damob23 in forum 3D Modelling
    Last Post: 16th Jul 2008, 12:52 pm
  5. Replies: 0
    Last Post: 12th Sep 2006, 08:57 pm
