Results 1 to 6 of 6
    Junior Member
    bell531's Computer Details
    windows 10
    Lenovo ThinkCentre
    AutoCAD LT 2012
    Aug 2009
    New Plymouth, New Zealand.
    21
    Default Rotate viewport so objects in model space are square to paper space.
    Is there a better way of doing this.
    Currently I grab the viewport ROTATE then REFERENCE the object in modelspace then use POINTS to choose something in paperspace (e.g. the drawing border).
    Then I reshape the rotated viewport with the grips to suit my paperspace.
    I am using AutoCAD LT 2012.
    I don't want the UCS changed globaly. Thanks.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,207
    I don't know LT, can you save a custom UCS? Apply it temporarily, activate it inside the viewport, and go back to World afterward. Use the PLAN command to orient the drawing to the UCS.
    breaking AutoCAD on a regular basis since 1991
    Junior Member
    windows 10
    Lenovo ThinkCentre
    AutoCAD LT 2012
    Aug 2009
    21
    It took me a bit of time to explore the options, I work in civil construction so the geographic coordinates are crucial. Good bit of learning, thanks for putting me in the right direction.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,589
    We trurn our road works around all the time in layouts, so orientate along sheet, normally use the UCS OB option for pick object, often give it a name also UCS S Road handy if you want to use it again. Just be carefull if using object that it does not have differring Z values as this scews up the UCS. At any time you can always go to like Cyberangel UCS W to get real world co-ordinates.
  5. #5
    Junior Member
    windows 10
    Lenovo ThinkCentre
    AutoCAD LT 2012
    Aug 2009
    21
    Thanks BIGAL,
    Good points there, I do use the z sometimes otherwise in the absense of FLATTEN in LT i use a little custom button I learned somewhere. Shame i'm stuck on Acad LT. I wish I had BricsCAD, then I could pick up some useful lisps and buy a modest add on for Earthworks volumes and still have money left over. Maybe one day.
  6. #6
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,207
    Quote Originally Posted by bell531 View Post
    AutoCAD has quite the learning curve, but once you get past it, you've got a lot of power at your disposal.
  1. rotate content in model space viewported in paper space
    By cat3appr in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Apr 2017, 03:45 am
  2. Send all objects on certain layer from paper space into model space.
    By gaddyzt in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2014, 06:51 pm
  3. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  4. rotate view in paper space but not model
    By paul1966 in forum AutoCAD Beginners' Area
    Last Post: 14th Mar 2010, 10:41 am
  5. Moving objects from paper space to model space
    By schneeflocke in forum AutoCAD Beginners' Area
    Last Post: 27th Feb 2009, 09:19 pm
