Results 1 to 6 of 6
    Forum Newbie
    Environmental
    AutoCAD 2014
    Oct 2017
    1
    Default Rotating Lines using the 3d Rotate tool?
    Hello! I have two lines of a cross section that, because of the way they were designed, were imported in between the top/front view (as seen in my first screenshot).
    I need these lines to be rotated so that they are viewed in top down only, that is, I need to rotate them 45 degrees from the current view up to the top down view, so that all z points are eliminated, so that I can have these two lines solely in the xy plane.
    I know I will need to use the 3d rotate tool, but I cannot for the life of me figure out how to rotate it around the x plane. Please help!
    The first image is how the lines are currently situated, that is, to view them as a proper cross section you need to be viewing them from an angle from the front/top down
    The second image is the view I want, but now we are not viewing a proper cross section, as we are not looking at them straight on.
    Senior Member
    Manufacture
    gazza_au's Discipline Details
    Engineering
    Manufacture
    Management/Stainless Fabrication/Design/Drafting
    AutoCAD 2015
    Apr 2010
    Australia
    132
    Try using the left view with the veiw cube.
    Use 3d rotate command
    drag a window to highlight all your part
    pick the lowest right point then pick a rotating axis (red)
    then specify the angle (-45 degrees) ?
    once done check if everything on Z plane is at 0
    if not you would have to select all and go to properties and change the Z values to 0
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    I have moved your thread to the AutoCAD 3D Modelling & Rendering Forum.
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    375
    Rather than using the "3D Rotate" tool (the 3drotate command) I would use the rotate3d command and specify the x axis and + or - 45°.
  5. #5
    Windows 7 64-bit
    16 GB
    Education
    Education
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    375
    One more thought, if the angle of rotation for the 2D polyline was not 45° I would consider using the ALIGN command and specify the beginning of the line for the first source point, 0,0,0 for the first target point, the second vertex of the line for the second source point, 1,0,0 for the second target point, and any vertex not collinear with the first two vertices for the third source point and 0,1,0 for the third target point.
  6. #6
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    If I understand what you have and what you need correctly, then just plain rotate is all that is needed. Setup in a right view, orient the ucs so you have x and y showing, rotate 45 degrees.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Problem with Rotate Tool
    By chubarka in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Nov 2016, 05:46 pm
  2. How to rotate crosshairs without rotating drawing...?
    By bumblebbabe in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Mar 2013, 08:45 am
  3. I can't see my object(s) rotate in real time when rotating using grips
    By ptatohed in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Feb 2012, 12:02 pm
  4. Repositioning via rotate - but not directly rotating
    By BigThumper in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2011, 04:13 am
  5. whant to rotate 90 deg. viewport, w/o rotating it in model?
    By goualon69 in forum AutoCAD General
    Last Post: 3rd May 2006, 06:20 am
