Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    Electrical
    AutoCAD 2016
    Sep 2017
    Townsville, NQ, Australia
    41
    Default Scaling in Model and Paper space
    I have done an exercise in Model Space, with scale 1:2, and I have Formatted the Points to be 2mm, which is a good size for the model space drawing ( attached), and stored this in the template I use
    When looking at the Paper Space Viewport, as the same scale, the Point Format is way too large ( see attached)
    Can anyone please advise why this is so, and what I should do to prevent it happening now, and in future drawings
    regards to all
    PJ
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    What is the current annoscale in modelspace?
    I believe it should display the same if they are identical.
    I prefer using annotative blocks for better control on paper.
    Use points only for modelling..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Objects that can be annotative include:
    Text
    Blocks & attribute definitions
    Hatches
    Dimensions & dimension styles
    Geometric tolerances
    Multileaders & multileader styles
    What benefit is derived from having a point on an object that could just as easily be accessed via an osnap setting like center or midpoint?
    AutoCAD 2013
    Nov 2011
    6,056
    Why are you drawing to a scale in modelspace?
    Everything should be drawn full sized in modelspace 1:1 .
    Do whatever scaling you want to do, later, through your viewport.
  5. #5
    AutoCAD 2017
    Jul 2015
    699
    Text
    Hatches
    Points are wonderful for retrieving xyz with a attached fields. But you better have them in a block
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    The question was directed at the OP.
  7. #7
    AutoCAD 2017
    Jul 2015
    699
    Sounds familiar
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    PJ01: What is PDSIZE set to?
  9. #9
    Full Member
    Electrical
    AutoCAD 2016
    Sep 2017
    41
    Quote Originally Posted by Dadgad View Post
    Yes !! Thanks for that comment. I meant to post this in Beginners, but landed here by mistake late at night.
    My custom template , when opened, gave a model space scale of 1:2, and I never noticed this. Have fixed that, and the scaling of the Points in the Paper Space (Layout) returned to normal too. I have selected the Point format to be 2%, not 2mm as stated above.
    I like using POINT command to give key point locations before drawing any lines and circles, especially using Relative command. I suppose that I could use relative command for placement of circles too, but still in the beginner stage, and open to any suggestions on how to approach a drawing
    thanks all for your comments, much appreciated
  10. #10
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    The modelspace scale? You mean the modelspace annotative scale, correct? This scale, shown below, does not change the scale of the objects in modelspace. It only simulates what your annotative objects will look like in a viewport. It is used to facilitate placing, and spacing dimensions, leaders, and notes, and any other annotative objects nicely so they will look good and not obscure any modeled objects once they get to a viewport scaled to the SAME scale as your modelspace annotative (viewing) scale.
    I use annotative dimensions, leaders, mtext, and the like. My work requires multiple sheets with multiple viewports set to many different scales. When I go to set my annotative dimensions in modelspace, I make sure to set my modelspace annotative scale to the same scale I intend to use in my viewport.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Scaling Problems!?! Model/Paper Space
    By katherine1992 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Feb 2017, 05:29 pm
  2. Fill color model space versus paper space.. newb question
    By dan_m in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Nov 2014, 09:06 am
  3. Acad 2010 - Text size changes in model space behave as if in paper space.
    By Trickinitup in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2011, 03:44 am
  4. HELP! Model/Paper Space Scaling Incorrect
    By beck08 in forum AutoCAD General
    Last Post: 26th Sep 2010, 12:13 pm
  5. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
