Results 1 to 4 of 4
    Forum Newbie
    Mechanical
    AutoCAD 2018
    Oct 2017
    4
    Default Need help with block insertion and ideas for auto-dimensioning.
    Hey. I'm a novice as far as automating things in CAD and was wondering how difficult it would be to implement two things which would save me a heck of a lot of time.
    1) I currently have to copy/paste a certain block to the midpoint of a bunch of line segments that exist on the same layer. Is it possible to populate these blocks at the midpoint of every line segment that exists on a specific layer?
    2) Is there a method for dimensioning a bunch of line segments of a polyline automatically? I'm thinking something akin to clicking on the inside of a shape composed of a bunch of lines (sort of like when using the bpoly command) and rather than having it just return a polyline, it would also create aligned dimensions associated with the different line segments.
    I apologize if either of these get asked about a lot, my AutoCAD knowledge is fairly basic and I'm just now exploring the idea that there's a better way to do things.
    Thanks for any responses!
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,417
    1 very doable there was a post a few days ago about labeling lines it may have been Grr that provided a pretty good answer.
    2 just search again its been posted here multiple times, Lee-mac,com has a nice one that produces all the properties of a pline.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,146
    Sorry to disappoint you but the answer is not that simple BIGAL has missed the LT label in your profile, and the solutions he points to are probably using Lisp which isn't available in LT. The approach in LT would require the use of macro's, and then you will still need to pick each item individually. Your other option would be to use the list command on all the selected items, and extract the coordinate information using excel's filter, then use a bunch of other features to get at and work out the X and Y mid points of each line. After that create a concatenated list that uses those mid points to create a script that inserts blocks and or uses the dimaligned command to place dimensions at another offset point (again you need to work that out in a formula).
    Yes doable, just not very quick, by the time you have it working you could probably have done it a dozen times manually, but is it fun - yeah I do this sort of thing daily, but only if it is for repeatable operations.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,043
    I have moved your thread to the AutoCAD LT Forum.
  1. Auto Dimensioning
    By Jake8090 in forum AutoCAD Beginners' Area
    Last Post: 20th Jul 2014, 11:52 pm
  2. Auto Rotate Label at block insertion
    By deano33 in forum AutoCAD General
    Last Post: 17th Jul 2013, 11:51 pm
  3. Lines Auto Dimensioning
    By Fire Alarm in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2011, 12:11 pm
  4. Auto Dimensioning in autocad
    By Anil.S in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Jun 2008, 11:02 am
  5. Auto dimensioning
    By bjasa in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Jun 2008, 07:24 am
