Hatch areas by layers or patterns for entire drawing or selected area
Baber62
I am looking for a lisp routine that will export hatch areas by layers and/or pattern for an entire drawing or a selected area in a drawing to an excel file.
I have a large number of drawings that I have to get through (over 100) and having to prepare a bill of quantities. Any assistance would be gratefully appreciated.
Here's a quick one:
(defun c:hareas	(/ _writefile a b key out s)
 (defun _writefile (filename lst / file)
   (cond ((and (eq 'str (type filename)) (setq file (open filename "w")))
   (foreach x lst (write-line x file))
   (close file)
   filename
 (initget 0 "Pattern Layer")
 (if (and (or (setq key (getkword "\nPattern or LayerName [<Pattern>]: ")) (setq key "Pattern"))
   (setq s (ssget '((0 . "hatch"))))
   (progn (setq s
	  (mapcar
	    '(lambda (x)
	       (cons (if (= "Pattern" key)
		       (vla-get-patternname x)
		       (vla-get-layer x)
		     (if (vl-catch-all-error-p (setq a (vl-catch-all-apply 'vla-get-area (list x))))
		       0.0
		       a
	    (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
   (foreach h s
     (if (setq b (assoc (car h) out))
       (setq out (subst (cons (car b) (+ (cdr b) (cdr h))) b out))
       (setq out (cons h out))
   (print (_writefile
	    (strcat (getvar 'dwgprefix)
		    (vl-filename-base (getvar 'dwgname))
		    "_Hatch_"
		    key
		    "_Areas.csv"
	    (mapcar '(lambda (x) (strcat (car x) "," (vl-princ-to-string (cdr x)))) out)
   (if (setq b (vl-remove-if-not '(lambda (x) (= 0 (cdr x))) out))
     (alert (strcat (itoa (length b)) " hatches have no area property!"))
(vl-load-com)
Edited by ronjonp
Thanks ronjonp, works fine for the pattern, however, I can't seem to select the layer name, tried entering the layer name itself but it's not working. Also routine does it for the whole drawing also need it to cover a selection set.
Change:
(setq s (ssget "_X" '((0 . "hatch"))))
to:
The way the code is written is to either tally hatch by layer name, or by hatch pattern name. No filter is built in.
I also added an alert above for hatches without an area property:
Hi ronjonp sorry couldn't get back to you earlier, still having trouble with the code to get the output by layer, any ideas where I'm going wrong?
The output for patterns you're looking for is not even close to your initial request? They layer output ( I'm guessing totals per layer ) should be fine other than it does not create a header.
Pattern Scale Colour Area
Ar-Con 10 Red 20
Ar-Con 50 Red 30
Ar-Con 50 Blue 45
Edited by ronjonp
