Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    AutoCAD 2016
    Jul 2008
    65
    Default Can these commands be executed without dialog boxes?
    I want to put this into a script. I need to select all instances of this block and change it's layer and linetype.
    I can't use a lisp since don't know programming.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Did you try searching for a lisp routine?
    Full Member
    AutoCAD 2016
    Jul 2008
    65
    That was my question: How to put this in a script.
    Full Member
    AutoCAD 2016
    Jul 2008
    65
    I wouldn't necessarily know how to modify a lisp routine to make it work.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Maybe someone has already written a lisp routine that will do what you want. Try a search.
  6. #6
    Full Member
    AutoCAD 2016
    Jul 2008
    65
    I did. There are. The one I found selects a block and chages it's color. But since I am not a programmer I do not know how to modify the lisp.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Why can't you just use the BEDIT command? Open the block in question in the block editor. Change it's layer and linetype via the Properties palette. When you close the block editor you'll be asked if you want to save your changes. Do so. When you pop back into your drawing all instances of the block will have been changed.
  8. #8
    Full Member
    AutoCAD 2016
    Jul 2008
    65
    I have around 80 drawings with the same mistake.
  9. #9
    Full Member
    AutoCAD 2016
    Jul 2008
    65
    I found this thread but the lisp to select all blocks of a certain name doesn't work and I don't know how to code.
    http://www.cadtutor.net/forum/showth...-Command/page2
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Try this it has no error checking as it was done quick, read the comments to understand what its doing. I did test it, it does not change stuff on various layouts as you did not mention that. It could be used with a script to do all 80 dwg's in one go, I did not want to confuse you with how to do that also. A hint though open explorer to where you have the lisp saved just drag and drop onto dwg and it will start up straight away saving a few steps.
    Code:
    (defun c:reset-blk ( / ss newlay newlt bname)
    (vl-load-com)
    (setq obj (vlax-ename->vla-object (car (entsel "\nPick Block")))) ;pick an object and make it a Vl object
    (setq newlt (getstring "\nEnter linetype name Bylayer")) ; enter linetype name
    (setq newlay (getstring "\nEnter layer name"))   ; enter new layer name
    (setq bname (vla-get-name obj))                  ; get the blocks name
    (setq ss (ssget "x"  (list (cons 0 "INSERT") (cons 2 bname))))   ; make a collection of the block
    (repeat (setq x (sslength ss))                                   ; loop through the collection and change stuff
    (setq blk (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) ; get a block
    ; (vla-put-color blk 0)                            ; change its color 0 is Bylayer
    (vla-put-linetype blk newlt)                     ; change linetype note BYLAYER
    (vla-put-layer blk newlay)                       ; change its layer
    (c:reset-blk)
  1. Ditch dialog boxes with the command-line form of commands
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 23rd Feb 2012, 09:20 am
  2. Dialog Boxes
    By Strouse3910 in forum AutoCAD General
    Last Post: 19th Dec 2011, 09:12 pm
  3. Dialog Boxes
    By RONK in forum Mechanical & MDT
    Last Post: 21st Jun 2010, 01:51 am
  4. Dialog boxes
    By maebus in forum Mechanical & MDT
    Last Post: 25th Mar 2009, 10:21 pm
  5. Dialog Boxes!!!!
    By Paul Mc in forum AutoCAD Drawing Management & Output
    Last Post: 1st Feb 2006, 08:22 pm
