Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Forum Newbie
    Electrical
    AutoCAD 2014
    Nov 2017
    8
    Unhappy millimeter dimensions in bmp image
    Hi. I'm new to Autocad. I've made an image to be used for laser printing. The image size is 5x6 mm. The problem is when I use BMPOUT command in Autocad the image is not in millimeters so when I import it in the laser printing software my design is much larger than it should be. I asked on autodesk and the only response I got was that I have to adjust dpi. I don't know how to do that or what it is.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    "DPI: Dots per inch is a measure of spatial printing or video dot density, in particular the number of individual dots that can be placed in a line within the span of 1 inch." Wikipedia
    From AutoDesk: "The BMPOUT command is not as flexible as plotting to a device to create a BMP file, because it has no options other than the file name and the objects to include."
    Forum Newbie
    Electrical
    AutoCAD 2014
    Nov 2017
    8
    Thanks. Now can you tell me how to change this in AutoCAD 2014?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    See previous post for an addition I made re: BMPOUT. You have more options if you plot to a device.
  5. #5
    Forum Newbie
    Electrical
    AutoCAD 2014
    Nov 2017
    8
    How do I plot to a device? I'm sorry I'm new to Autocad
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
  7. #7
    Forum Newbie
    Electrical
    AutoCAD 2014
    Nov 2017
    8
    Thanks I'll give it a try.
  8. #8
    Forum Newbie
    Electrical
    AutoCAD 2014
    Nov 2017
    8
    I tired using the plotting command and since it did not have the option of plotting a bmp file I chose PNG. Now I didn't have the option of using any unit other than pixels. I tried playing around with scaling (x pixel = y unit) that didn't help either because other than hit and trial I had no other way to find the appropriate size.
    Next I saw a video suggesting the use of -DWGUNITS to change the dimensions of drawing. I did that and changed my drawing units to millimeter. When I used BMPOUT to export the image it was the same problem.
    I feel like AutoCAD just wants to **** me off at this point. I've tried plotting, -DWGUNITS, UNITS, what else can I do? Also why are there so many commands to change the units? Can't they just make one and not make me want to put a hammer through my computer?
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    The knowledge based article I provided the link to above detailed how to add a device and then how to plot to said device (to create a BMP file). Did you follow the instructions?
    Re: units. They are a convention created for those of us who can't get past the concept of 1 unit can equal one of anything (an inch, a millimeter, a chain, a rod, a lightyear, etc.).
    BTW...your image is quite small 5x6mm.
    300 dpi is considered to be good quality when it comes to printing an image. 1 inch = 300 pixels. So, if we were using inches, a 5x6 image would require 1500x1800 px (pixels) to print at 300 dpi. However, you are using millimeters. You'll have to do the math.
  10. #10
    Forum Newbie
    Electrical
    AutoCAD 2014
    Nov 2017
    8
    Yes I did. And even after creating a new plotter for BMP files and trying to change its properties I only had the option of changing the pixels.
  1. Adding dimensions to 3D image...need help.
    By mdd in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Oct 2011, 08:19 pm
  2. How can i setup units millimeter?
    By salim in forum AutoCAD Drawing Management & Output
    Last Post: 30th Oct 2010, 03:59 pm
  3. How can change from INCH to MILLIMETER?
    By Faouweb in forum Autodesk Inventor
    Last Post: 29th Oct 2010, 01:15 pm
  4. meter or millimeter
    By renzon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Jul 2007, 11:55 am
  5. Converting the whole drawing from feet to millimeter
    By ot_gert in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2006, 01:27 pm
Tags for this Thread
