Results 1 to 3 of 3
    Forum Newbie
    Civil
    AutoCAD 2018
    Nov 2017
    1
    Default Creating Dynamic Block for Channelizers
    I am trying to create a dynamic block for inserting channelizers in traffic control plans. I am new to dynamic blocks and seem to be missing something. I want it to do almost what it's doing except the first channelizer isn't lining up with the rest of them creating a weird "dent" in the straitght line and the array grip moves out well past where the objects are, so say i need 500' of channelizers, i have to move the grip well out the 100' in order to get the channelizers to show up for the 500'.
    I would also like to be able to change the array distance in between the channelizers, is there a way to do this without creating multiple blocks with different array amounts?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    I have moved your thread to the AutoCAD Drawing Management & Output Forum.
    Junior Member markwheeler303's Avatar
    Construction
    AutoCAD 2017
    Oct 2017
    20
    It looks like the array you have used is functioning in a very weird way. As you rotate the grip it starts actually curving the arrayed items.
    There is still no function in dynamic block parameters to allow for variable array distances. hopefully one day, as it would be the holy grail of dynamic block making.
    That said it can be done with dimensional and geometric constraints.
    How exactly would you like this the function? Does it just need to array in a straight line at set distances?
    If you could give me a quick brief on its actual; functions I can try and make one that satisfies all goals or advise you on a better way to do it.
  1. Need help creating a dynamic block that has a variable array distance for a rectangle
    By dollada06 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Nov 2017, 07:58 am
  2. Replies: 0
    Last Post: 16th Oct 2015, 05:52 pm
  3. Creating a dynamic block with attribute definition
    By KoTa04 in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jun 2013, 06:26 pm
  4. Replies: 5
    Last Post: 15th Jul 2010, 08:15 am
  5. Problem creating a dynamic block
    By nscherneck in forum AutoCAD General
    Last Post: 27th Jun 2008, 11:01 am
