Results 1 to 2 of 2
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    Default Filter DWG using xdata fiield
    I'm checking to see what can be done with xdata. Somehow not all data is catched using this method. Would be handy to filter out ALL Revit inside DWG .. IN ONE STROKE ..
    Documentation
    http://adndevblog.typepad.com/aec/20...ata-xdata.html
    Result filter on xData
    https://twitter.com/halammerts/statu...04844662288385
    Modelling is done with two hands, 2d & 3d. Let it work together..
    AutoCAD 2017
    Jul 2015
    671
    The theory doesn't work
    DWG used in Revit (*) gets a xData Revit. Pity
    https://youtu.be/xs1L8pY87ZA
    * import, did not check link method
  1. Need help with EED/Xdata
    By BCL in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jul 2017, 03:48 am
  2. ssget: add a filter for xdata
    By MastroLube in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Oct 2016, 06:22 pm
  3. Xdata
    By jevrem1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Oct 2014, 01:12 pm
  4. xdata lisp
    By Lord V in forum AutoCAD General
    Last Post: 22nd Jun 2010, 02:51 pm
  5. Replies: 0
    Last Post: 2nd Nov 2006, 11:51 pm
