Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member Saqib_theleo's Avatar
    AutoCAD 2010
    Jan 2012
    91
    Question How I can make 3d pipe according to these drawings?
    Hello everyone, I can make simple 3d objects but I don't know how to make 3d pipe as showing in this drawing. Simple 3d pipe is simple by making a circle and sweep it around the Poly line, but if someone can guide me how can I make this kind of 3d pipe I'll be thankful. Thanks.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,139
    A pipe is one of the easiest just draw a circle use rotate3d to align it to the end of say a 3dpoly then just extrude and use Path Z's are supported.
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    This illustrates a step by step method to get the compound bend pipe run. I assumed the elbow radius to be 5 at all bends.
    AutoCAD 2010
    Jan 2012
    91
    Hi SEANT, Thanks for your help, I tried to follow these steps you used, Step 1 to 3 are easy but after Surface Extrusion I could not get the Intersecting Line (required 3d path) by Intersect command. Can you please tell how did you do that and did you use radius command after getting 3D path. Hi Bigal, Yes making 3d pipe is simple but I was looking for the 3d path from these two lines. Thanks.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Check your drawing and make sure the extruded surfaces actually intersect with each other prior to invoking the command. My guess is your extrusion of the top view is in the wrong direction. Why is the overall length of the pipe (end to end) different in the two views? The length in the top view is shorter than the length in the side view.
  6. #6
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    I used AutoCAD 2016 for the intersection - I'm not sure if AutoCAD 2010's Intersect command is compatible with Surfaces. And yes, I did reorient the UCS to create the fillets. Each individual path was then used to sweep a solid.
  7. #7
    AutoCAD 2010
    Jan 2012
    91
    Hi ReMark, yes length is little shorter I didn't notice but not big problem, I just wanted to learn the procedure to make it this way and my extruded surfaces are intersecting with each other. Thanks.
  8. #8
    AutoCAD 2010
    Jan 2012
    91
    Hi SEANT, ok but right now am using laptop where CAD2007 is installed. I'll try this with some later version and one last thing did you use 3 point UCS to reorient the UCS.Thanks.
  9. #9
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    Quote Originally Posted by Saqib_theleo View Post
    . . . . did you use 3 point UCS to reorient the UCS . . . .
    Indeed, I did.
  10. #10
    AutoCAD 2010
    Jan 2012
    91
    Alright, thank you for your time and help for making me understand these things. GBY.
  1. How to make Pressure Pipe not see through from plan view
    By jchandler5008 in forum AutoCAD Drawing Management & Output
    Last Post: 6th Feb 2014, 09:48 pm
  2. Replies: 2
    Last Post: 26th Feb 2013, 10:20 am
  3. Question Help: Make 2d pipe with program lisp
    By deco_sakurai in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Aug 2012, 03:16 am
  4. Help to make Pipe in 2d double line
    By sayhi_sanjay1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jul 2012, 12:59 pm
  5. Replies: 4
    Last Post: 27th Sep 2010, 09:50 pm
