Can the Gear rotate?? You can answer the question !
rocket
The three gears in a flat plane like that will not work. It doesn't take a Solidworks video to prove the point.
This is a fun question. But It's nice. The Solidworks Video gives the exactly answer. The important is SolidWorks Video reminded us see everything in 3D field
  • 2 weeks later...
The shadowing in the original photo of the three gears indicates that the gears lie on the same plane unlike the lame Solidworks solution that places them on different planes (and introduces a 4th gear). If you want to think out-of-the-box for a "yes" answer to the question I would suggest consider rotating the 3 gears as one unit about an axis parallel to the viewing plane and not perpendicular as most viewer will assume.
