Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
  1. #21
    Full Member
    LanloyLisp's Computer Details
    Window 7 Premium
    AutoCAD 2013
    Jun 2013
    La Union, Philippines
    34
    Where did the drawing originate from?
    What program was the drawing created with?
    Did you "borrow" any content from any other drawing and insert it into this drawing?
    Do you regularly clean up your drawings using such commands as Overkill, -Purge, Audit and WBlock?
    Some of the objects are extracted from Revit files where it came from, and for sure I copied some objects in different drawings.
    I usually purge my drawings on each save, I recover and audit the file rarely and used it once when AutoCAD suddenly crashes.
    Original File:
    https://we.tl/PVoAojkv8s
  2. #22
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    For a drawing that is 41MB it sure loaded fast. I have a 5MB 3D model that takes longer to load than your drawing.
    Well I ran the Overkill command and reduced the number of objects in the drawing from 2366 (2 not in current space) to 1321 and it dropped the file size from 41MB to 208KB.
    Then I WBlocked the contents of model space to a new drawing and the file size dropped to 190KB.
    Running the Audit command found and fixed two errors with the database.
    Perhaps the file bloat was a by-product of Revit? I'm not sure.
    My advice would be to practice good CAD procedures and regularly clean up your drawings before saving them. And if you are going to "borrow" content from another drawing, especially if the drawing was created within another program then "saved as" an AutoCAD .dwg file, retain a "clean" copy of your original drawing under a different name as insurance in case things go badly.
  3. #23
    Full Member
    Window 7 Premium
    AutoCAD 2013
    Jun 2013
    34
    Thanks for the tips ReMark.. One thing I found out, saving it to 2007 version
    makes the file also lesser.
  1. Blank DWG with a large file size...
    By lamensterms in forum AutoCAD Drawing Management & Output
    Last Post: 9th Mar 2014, 07:54 pm
  2. File size too large
    By Viper in forum AutoCAD General
    Last Post: 8th Jun 2011, 11:38 am
  3. Ridiculously large file size increase
    By CMuscavage in forum AutoCAD Drawing Management & Output
    Last Post: 7th Apr 2010, 08:18 pm
  4. issues with large file size
    By Stephen Shafer in forum AutoCAD General
    Last Post: 5th Apr 2009, 04:05 pm
  5. extremly large file size?
    By comcu in forum AutoCAD Drawing Management & Output
    Last Post: 19th Aug 2006, 07:11 pm
Tags for this Thread
