Results 1 to 8 of 8
    Full Member
    Multi-disciplinary
    AutoCAD 2013
    Oct 2017
    34
    Default Select specified layer Objects and delete
    Hii,
    i have layer names like "Earth Line'", "Steel Line", "Concrete Line" etc..
    so i need select all mentioned layer named containing objects and delete them.
    any code for this task?
    Thankyou..
    Full Member
    LanloyLisp's Computer Details
    Window 7 Premium
    AutoCAD 2013
    Jun 2013
    La Union, Philippines
    34
    Command: LAYMRG
    Give it a try..
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Not tested:
    Code:
    (defun C:test ( / acDoc SS )
      (cond
        ( (not (ssget "X" '((8 . "Earth Line',Steel Line,Concrete Line")))) (prompt "\nNo Selection.") )
        ( (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
          (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)
          (vlax-map-collection (setq SS (vla-get-ActiveSelectionSet acDoc)) ''((x) (vl-catch-all-apply 'vla-Delete (list x))))
          (vla-Delete SS)
    (vl-load-com)(princ)
    Full Member
    Multi-disciplinary
    AutoCAD 2013
    Oct 2017
    34
    grrr thank you very much. it is working.
    can you provide selecting objects only? instead of delete.
    Thank you.
  5. #5
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Quote Originally Posted by Raje View Post
    Thank you.
    Thanks for confirming,
    This should limit the selection to the active viewport (as my previous suggestion selects objects in all viewports - and that might be unwanted) :
    Code:
    (defun C:test nil
      (sssetfirst nil
        (ssget "X"
          (list
            '(8 . "Earth Line',Steel Line,Concrete Line")
            (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))
    Full Member
    Window 7 Premium
    AutoCAD 2013
    Jun 2013
    34
    Quote Originally Posted by LanloyLisp View Post
    Give it a try..
    My bad.. I thought you want to delete the layer itself..
  7. #7
    Full Member
    Multi-disciplinary
    AutoCAD 2013
    Oct 2017
    34
    Grrr thank you, it is also worked fine.
  8. #8
    Full Member
    Multi-disciplinary
    AutoCAD 2013
    Oct 2017
    34
    LOL its ok and thank you..
  1. Select objects to new Layer
    By jyan2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jun 2017, 09:23 pm
  2. Select all objects in a single layer: how?
    By Sudan in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2015, 08:21 pm
  3. Select All Objects on a Certain Layer
    By resullins in forum AutoCAD General
    Last Post: 28th Dec 2011, 01:22 am
  4. Replies: 0
    Last Post: 27th May 2011, 11:30 pm
  5. Can't select objects to delete them(layer not frozen or locK
    By NathanSF in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Feb 2006, 05:44 am
Tags for this Thread
