Results 1 to 3 of 3
    Full Member
    Civil
    Civil 3D 2015
    Mar 2017
    28
    Default What is the way to add already highlighted objects to a selection set?
    What is the way to add already highlighted objects to a selection set? I feel like I have seen the answer before but I cant remember what I searched to find it. Like how you can select object before you use the move command and autocad will move the objects that were already selected. I am looking to use the TSPACEINVADERS command and have the selected text then have a red circle put around them. Thank you for any help in advance.
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    810
    Make sure pickfirst is set to 1 then calling (ssget) will create a selection set of the highlighted objects.
    Full Member
    Civil
    Civil 3D 2015
    Mar 2017
    28
    Thank you. I knew I had seen it before just could not remember.
  1. Selection sets- How to select objects on top of other objects?
    By LosGirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Apr 2014, 05:54 am
  2. Add objects to a new Selection Set
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th May 2013, 06:58 am
  3. Objects, text, etc. are highlighted when I pan over
    By nrschmid in forum AutoCAD General
    Last Post: 20th Jun 2010, 06:49 pm
  4. objects selection
    By salman in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2009, 04:03 pm
  5. delay in selection of objects/selection windows
    By RedRobMol in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 01:34 pm
Tags for this Thread
