Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Forum Newbie
    Structural
    AutoCAD 2018
    Nov 2017
    9
    Unhappy Make User Variable From Mtxt
    Dear Sir's
    I want to make user variable "Let's say USER1" to be equal to number 15 which is written in txt or mtxt anywhere in my drawing
    so if anyone change this txt or mtxt to 16 the USER1 will be changed to 16 also
    I hope my explanation was clears enough
    thanks and regards
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    You would be better of with using xdata rather than the USER variables just needs some else code to use it and it wrong.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    I have moved your thread to the AutoLISP, Visual LISP & DCL Forum, please post in the most appropriate forum.
    Forum Newbie
    Structural
    AutoCAD 2018
    Nov 2017
    9
    Quote Originally Posted by BIGAL View Post
    Dear sir
    Thanks for your help
    here is my full idea
    i made this diesel expression
    $(substr,$(getvar,dwgname),1, $(getvar,"USERI1"))
    i have set custom variable called USERI1 to 11
    so this expression is to give me the first 11 letters in my drawing name
    all i need is to have some flexibility to change the number of letter i get from my drawing name
    i'm not familiar of xdata function
    can i use the xdata with diesel expression and how ?
    Regards
  5. #5
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    761
    I assign many values to custom Drawing Properties and reference them with fields. Then if I need to change for example the number of pages or name of the engineer of record I simply do it in Drawing Properties and it's updated everywhere automatically. You can do the same with Custom Sheet Set Properties.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  6. #6
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    761
    I've added a drop-down in my Ribbon with lisp macros for the Propulate command like:
    Code:
    ^C^C(command "Propulate" "A" "D:/Users/BeaufordT/AppData/Roaming/Autodesk/VLisp/TomBeauford.prp" "U" "C")
    to set my name as the Drawn by and my boss as the Engineer of Record who's going to sign and seal the drawings.
  7. #7
    Super Member
    not applicable
    Jun 2016
    633
    @MahReda:
    What part of the dwgname do you want to remove?
    Note: You can directly reference the file name without the extension in a field.
    BricsCAD 18
  8. #8
    Forum Newbie
    AutoCAD 2011
    May 2013
    6
    Quote Originally Posted by MahReda View Post
    Dear Sir's
    thanks and regards
    I would suggest using fields like Tombu mentioned.
    Quote Originally Posted by tombu View Post
    This is exactly what we do, custom properties and pieces of text/mtext that have fields that reference the custom properties. I love it, saves so much time.
  9. #9
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    279
    Why dont you use the macromode variable?
  10. #10
    Forum Newbie
    Structural
    AutoCAD 2018
    Nov 2017
    9
    Quote Originally Posted by Roy_043 View Post
    @MahReda:
    i want to show first 11 letter of the drawing name
    but unfortunately in some drawings i need to show only 10 or 9 letters
  1. Returning last user variable
    By Andrew1979 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2015, 03:42 am
  2. MASK TXT or MTXT lsp=>VB ??? SETDATA/GETDATA/SELECTIONSET/MTXT
    By acad386bis in forum .NET, ObjectARX & VBA
    Last Post: 8th Jul 2014, 10:18 am
  3. Replies: 6
    Last Post: 19th Oct 2012, 02:55 am
  4. New autocad 3d user trying to make custom junction boxes
    By SublimeSilence in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Dec 2010, 06:22 pm
  5. copy Mtxt into block
    By Ozymandias in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2010, 05:23 pm
