Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Forum Newbie
    Structural
    AutoCAD 2018
    Nov 2017
    9
    Quote Originally Posted by tombu View Post
    I assign many values to custom Drawing Properties and reference them with fields. Then if I need to change for example the number of pages or name of the engineer of record I simply do it in Drawing Properties and it's updated everywhere automatically. You can do the same with Custom Sheet Set Properties.
    Can u explain to me how to do this ??
  2. #12
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    279
    Type command DWGPROPS. These settings can be shown on screen with fields.
  3. #13
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    759
    Quote Originally Posted by MahReda View Post
    Like Aftertouch said you can add custom variables and values in DWGPROPS. The Express Tools command PROPULATE alows you to quickly load a complete set of property variables and values saved in a prp file. It's used by lots of CAD people and there's a bit of lisp written for modifying them as well.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  4. #14
    Forum Newbie
    Structural
    AutoCAD 2018
    Nov 2017
    9
    Quote Originally Posted by Aftertouch View Post
    ok now i set new dwgprop named DN and equal to 11
    when i use it in diesel expression like this
    $(substr,$(getvar,dwgname),1, %<\AcVar CustomDP.DN>%)
    it works fine but when i save and close then open my file again i find that the diesel expression turned into
    $(substr,$(getvar,dwgname),1, 11)
    so if i changed my DN variable again, diesel expression will never be changed automatically
  1. Returning last user variable
    By Andrew1979 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2015, 03:42 am
  2. MASK TXT or MTXT lsp=>VB ??? SETDATA/GETDATA/SELECTIONSET/MTXT
    By acad386bis in forum .NET, ObjectARX & VBA
    Last Post: 8th Jul 2014, 10:18 am
  3. Replies: 6
    Last Post: 19th Oct 2012, 02:55 am
  4. New autocad 3d user trying to make custom junction boxes
    By SublimeSilence in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Dec 2010, 06:22 pm
  5. copy Mtxt into block
    By Ozymandias in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2010, 05:23 pm
