Results 1 to 6 of 6
    Junior Member PaddlesUpRiver's Avatar
    PaddlesUpRiver's Computer Details
    Windows 64-bit
    Dell Optiplex 390
    Dual Monitors Dell and HP
    Civil
    PaddlesUpRiver's Discipline Details
    Engineering Design & Project Management
    Civil
    Stormwater and Wastewater Design
    Civil 3D 2017
    Sep 2013
    USA
    11
    Default Display Order Not Working As It Should
    I've used AutoCAD for years and I've never had this problem. On one of my sheets I have a Location Map showing the general area of the construction project in a viewport. Then I have another viewport showing the state map which is suppose to sit on top the Location map. I also have some text (not in a viewport but on the sheet itself) with an arrow pointing to the project area.
    The problem is no matter which display order command I use: the text, arrow, and state map always disappear under the Location map. But the Location map should be under everything. I've exhausted my mind trying to figure out how to resolve this -- even re-creating the viewports and whatnot to no effect.
    Please help
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,153
    The two maps are in two different viewports? Have you tried combining them so that they show up in one viewport? Failing that, could you paste the state map on top of the vicinity map in the image itself?
    breaking AutoCAD on a regular basis since 1991
    Windows 64-bit
    Dell Optiplex 390
    Civil
    Civil
    Civil 3D 2017
    Sep 2013
    USA
    11
    Combining them into one viewport doesn't work well because the overlap is too great. It really needs to bo offset and overlapped on the sheet and not in model space. Also it doesn't fix the problem as to why this is happening. Any ideas?
    Windows 64-bit
    Dell Optiplex 390
    Civil
    Civil
    Civil 3D 2017
    Sep 2013
    USA
    11
    Putting all the text and images into one viewport took care of this issue. However, I have overlapped viewports before in AutoCAD before without coming across an issue like this and it would be nice to know what the problem is for the future.
    Thank you for you help CyberAngel.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,880
    Does it plot correctly?
    Could be a list of things causing it, including a bug in AutoCAD, corrupt drawing, graphics card and/or driver.
    Can you post the .dwg, at least enough to see if the problem occurs on others AutoCAD and computer?
  6. #6
    Windows 64-bit
    Dell Optiplex 390
    Civil
    Civil
    Civil 3D 2017
    Sep 2013
    USA
    11
    So the drawing does not plot correctly. Even the text on the sheet is plotted under the viewport no matter what I do.
    Here's a link to the file, it should give a better idea of what the issue is.
    https://www.dropbox.com/sh/pw9gs2hgt...PDyz1ANia?dl=0
  1. Object Order, Display Order, Transparency?
    By EatingSteak in forum AutoCAD Drawing Management & Output
    Last Post: 29th Apr 2015, 03:00 am
  2. Display Order
    By Marc5 in forum AutoCAD General
    Last Post: 1st Aug 2011, 02:56 pm
  3. Display Order
    Last Post: 7th Jul 2011, 01:52 pm
  4. display order
    By dirtlegg in forum Civil 3D & LDD
    Last Post: 23rd Dec 2010, 03:31 pm
  5. display order help
    By kaya in forum AutoCAD General
    Last Post: 2nd May 2006, 09:42 pm
Tags for this Thread
