Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    howitzer's Computer Details
    Windows 7-64 Pro
    8GB
    nVid-something
    Civil
    howitzer's Discipline Details
    Civil Engineering Technician
    Civil
    Civil 3D 2015
    Dec 2012
    Iowa
    36
    Default Survey: How important is linework accuracy?
    I'm interested in what others do and/or think, wondering if I'm on track, or whacked out.
    How important is it that linework be accurate? By accurate I mean, lines that are supposed to be parallel are indeed parallel, not a couple seconds off... two lines that are supposed to meet at their endpoints, do indeed meet at their endpoints, not overlap... things like that.
    My position is, or has evolved to be, that you save yourself so much time and trouble and heartache in the long run if you're accurate from the very beginning. It's easier to do it right from the start than it is to do it wrong then make it look right, especially where dynamic labeling is concerned. Even if it ostensibly 'doesn't matter because it won't be built that close anyway'. If I'm laying out a sidewalk, for example, I expect the sides of the sidewalk to be parallel. I expect lines/arcs to be tangent (excepting the rare scenario where you have no choice for whatever reason).
    Others in my firm do not believe I should be so dogmatic about it, that there are times where it's just wasting time for something that will never matter. Yet, in my experience, my rear end has been saved from blame because my linework was accurate. If nothing else, there's potential liability reasons.
    Your thoughts?
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,591
    To me it is actually easier and quicker to do things accurately, and it looks so much nicer. From the stand point of getting something like a sidewalk built it probably doesn't matter, but I can't bring myself to "sketch" with CAD.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,411
    Your listed as CIVIL so with GPS setouts, 3d machine control accuracy is becoming more important. Its so easy to do it correct using snap and ortho to say it does not matter is not the sign of a good designer.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,146
    I probably spend half my time making other peoples drawings accurate, I have to take off quantities from drawings supplied by others, and it is so much easier to do that if polylines are closed and not made up of overlapping objects, it's a fairly simple formula to find the length and width of a wall given perimeter and area, but only if that information is accurate. For a 160 apartment tower block, it can take me nearly a week to clean up the drawings and get things on sensible layers. It is then just a question of days to take off the quantities and create the schedules, doing all that normally is 3 to 4 weeks.
    And by far the best drawings, in general, come from the structural engineers, that's just a question of checking for odd errors. Drawings from Architects, that's just hoping that you can find a few that are straight. I think many of the errors are due to how "other" programs are converted to dwg.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    It's too easy to draw it accurate and correct to accept anything less. Like rkent, I see no reason to sketch with AutoCAD.
    I fix any and all drawings I get or come across with inaccurate CAD work, if I am to work in them, if someone just wants something printed, I rarely bother to check it over for such things unless it just doesn't look right. Like steven-g, I find some programs convert poorly to dwg.
  6. #6
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    It's been my experience that, once an error creeps in, it will get carried through everything that connects with it. An architect will use fractional units and believe that getting within 1/4" is close enough. In other words, he'd never see a difference as large as .12. After a few more near misses, each one amplifying the ones before, he'd wonder why his stuff wasn't lining up properly.
    As SLW210 says, there's no excuse for doing it wrong when you have the tools to do it right. The people who will use your drawings are expected to work within certain tolerances. You owe it to them, and everyone else, to do the same.
    breaking AutoCAD on a regular basis since 1991
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Accuracy is paramount in the world of design. Anyone who tells you otherwise should be doing something else.
    A defect in a measuring device used to polish the mirror for the $1.5 billion Hubbell telescope made it virtually useless. It took a second mission (and additional monies) to fix the problem.
  8. #8
    Senior Member dtkell's Avatar
    dtkell's Computer Details
    Win7
    Intel I5 4670
    16mb
    Civil
    dtkell's Discipline Details
    Drafter/Designer
    Civil
    AutoCAD 2014
    Dec 2006
    San Diego, CA, USA
    152
    I thought the ease of drawing accurately was one of the benefits of using a computer aided drafting program. If you don't want accuracy, use a pencil.
  9. #9
    Full Member
    Windows 7-64 Pro
    8GB
    nVid-something
    Civil
    Civil
    Civil 3D 2015
    Dec 2012
    Iowa
    36
    Thank you all for your replies. It sounds like we're all pretty much on the same page... no pun intended.
    I like the word 'sketch' for what I am describing. I think that's highly descriptive. The way I portrayed it is that, if accuracy isn't important, then we can buy some lesser program than AutoCAD and save a lot of money... but we don't, because accuracy IS important.
    Turns out that I am not the only one who fixes things that aren't right when I get a drawing from someone else. Even if it's someone within my own company. If I get a drawing from an architect my mind is already conditioned to know that I will be reconstructing the majority of their drawing. I once had to trash literally an entire site layout once because not a single thing was accurate. Even the arcs for curb returns was just a series of short lines, all wildly inconsistent in length, that looked fine in a plot on paper, but served no useful purpose whatsoever.
  10. #10
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    638
    My drawings are not accurate at all I even tell people don't use my drawings to confirm the distance or the size of some feature that may be on the drawing. Most of the time the drawings I get are vectored PDFs that I convert to DWG. Then I have to scale them up. Of course doing fire alarm drawings accuracy of the drawing is not the most important part it's showing where the devices are going and how many. I know it sounds strange but my drawings are only for a relationship between devices installed and to where they are going. Any thing that requires any accuracy I show in a typical or a detail with dimensions. Rule of thumb is not to have your thumb where the hammer is going to hit. Translated leave the hammer alone and don't hold nails.
  1. Accuracy
    By chrisdarmanin in forum AutoCAD General
    Last Post: 11th May 2016, 08:50 am
  2. Accuracy not spot on.
    By JamesP in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2009, 10:58 am
  3. Accuracy
    By daveyboyd in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Apr 2008, 05:29 pm
  4. Important (4 me ...)
    By MaTrIxakos in forum AutoCAD General
    Last Post: 1st Jul 2005, 09:39 pm
